Question about Intel Desktop Board SE440BX-2 Motherboard
I have an intel SE440BX-2 that does not recognize my mouse and keyboard. The scroll lock, num lock, and caps lock all flash repeatedly. The keyboard and mouse do not work at all. Tried 2 different hard drives but got the same results. If it is a problem with my bios, how do I fix it? The computer was used in a business before I got it.
  • Greg Albro Feb 23, 2009
    I tried 3 different keyboards and 3 diferrent mice.
  • Chuck May 11, 2010
    did you try another keyboard and mouse?
  • 530 Answers
Hi im josh in cebu.friend if it wnt detect the probem is on your bios setup or on your motherboard parts like the cmos batt. you go to bios setup then go to pheriperals then choose enabled keyboard and mouse. or try to remove your cmos batt then afterr several seconds.install back firmly and tightenly. then reboot your pc.this will help you a lot good luck
Posted on Feb 23, 2009
The keyboard just stopped working. I plugged in my old keyboard, an HP, and it does not work either. Whichever keyboard I plug into the tower, the Num, Caps, and Scroll Lock lights flash for one second,...
Update your keyboard drivers. You only needy our mouse for that. Go to E-Machines homepage and search for your model number, then look for keyboard drivers. Good luck to you! Please leave me a good rating, thanks! :)
Jul 27, 2011 | E-Machines AAFQ50400000K0 Keyboard
if your caps light is on a light will/should show on your keyboard
hope this helps
On-screen real-time indicator showing the status of the Num, Caps and Scroll Lock buttons on the keyboard. NumCapsScroll Indicator monitors their status and indicates it in the System Tray with its icon, with a tool-tip when you mouse-over its System Tray icon, with a small On-screen Keyboard-like panel and a sound indicator. It's also an identical utility for laptops that are not supported with Num, Caps and Scroll Lock LEDs on their Keyboards.
What's new in this version: Version 7.0 is compatible with Windows 7.
Apr 06, 2011 | Computers & Internet
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
Feb 15, 2010 | IOGear GCS632U 2-port KVM Switch
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
About Mainboard
remove all RAM modules - system should beep when you switch it on. If not then your CPU is not working.
Can you see anything on the monitor?
Does the keyboard lights flash when you switch on after several seconds (caps lock, num lock, scroll lock lights flash)
Aug 07, 2008 | Intel Motherboard
Want to change priorities of boot in BIOS
This link is for the owners manual on that board,
On page 47 it states F2 is used to get into the bios, press repeatedly while booting so you don't miss the window, and of course check you keyboard, it should flash the caps,num, and scroll lock lights on boot.
Hope this helps
Mar 07, 2008 | Intel D850MV Motherboard
Aspire RC 500 - Acer w'less k'board & mouse packed up battery o.k
have you tried going into BIOS and setting Num Lock ON in startup? Do the Num Lock / Caps Lock and Scroll Lock flash when you boot up?
Check the pins if using PS/2 or is it a USB keyboard?
Dec 12, 2007 | Acer Aspire L100 PC Desktop
Intel Desktop Board SE440BX-2 Motherboard Logo
110 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
