Question about Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive
Wont read ext hard drive...says bad sectors...
Took to a local computer store! they said that they have tried 2 different recovery programs...they said my only option is to send my external hardrive to a "clean lab" company and have them physically pull the hardrive apart in a "clean lab" and try to salvage the last four years of my family pictures.  any ideas...they quoted me a hefty price in order to do this ?
  • 728 Answers
Have you tried goggling for data recovery software. There are a lot of free ones if you had that to your search. But, I've used several paid for ones that worked. I'd try to trail versions to download and first see if can read the drive. If it can't the next thing I would do, is to dismantle the case around the hard drive, and take out the physical hard drive and switch the back pins to Slave, and add it to your computer. (make sure you have your main drive as Master) Then as a slave drive you have a lot more options to recover data.
Good Luck
Mark
Posted on Feb 23, 2009
Can I fix my Seagate hard drive to bootable?
Hi, two things to try.
1. If you have the Win7 cd/dvd, go here and read:
http://www.bleepingcomputer.com/tutorials/start-the-windows-7-recovery-environment/
But I'm thinking that you have a few bad sectors in the HD's boot area (educed from your tzak.tzak description - which is head seek (bang) trying to find the boot sectors). Which I'm not sure that Win7 recovery can cope with. But check out this link and read/follow links:
https://answers.microsoft.com/en-us/windows/forum/windows_7-system/how-to-fix-the-boot-sector-of-windows-7/deb6ad12-a6b1-46fc-9786-240f66f9143e
And this link (better?):
https://answers.microsoft.com/en-us/windows/forum/windows_7-system/restoring-windows-7s-master-boot-sector-to/435f7bf7-9d5b-4741-9746-945ff06e6251
or
2. Go here and get SystemRescueCd:
http://www.sysresccd.org/SystemRescueCd_Homepage
It contains many tools for the repair of malfed systems.
You will want to use this tool: TestDisk
TestDisk[4]
Popular disk recovery software. Recovers lost partitions and repairs unbootable systems by repairing boot sectors. It can also be used to recover deleted files from FAT, NTFS and ext2 filesystems. File system recovery is supported for reiserfs, ntfs, fat32, ext2/3 and many others.
In closing, I would get a new HD, maybe a SSD? to replace your original hard drive (It may be failing, or it took a hard knock while in the boot phase, causing head-bang in the boot sector - not good). Make the new drive your master and use the old one for misc. data that you have originals of, i.e. music cd's, dvd movies, programs off-loaded from Tivo/DVR, etc.
Hope this at least gets you going in the right direction...
Oct 25, 2014 | Seagate BARRACUDA Computers & Internet
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
500gb Seagate external. Shows in Device Manager, but 0 data, 0 space available: had three partitions, lots of data. Now shows status RAW. Is there anyway to access, or am I stuck with a recovery servi
Do a google on "seagate LBA 0" there are some diy options.
If it's just a case of bad sectors these guys can help you do remote data recovery over the net. http://FreeDataRecovery.us
Sep 26, 2012 | Seagate FreeAgent Pro 500GB External USB...
I have an 500GB toshiba external hardrive,it still has 50G more space left..however when i tried to open it again..it wont open...it only shows the properties and said that windows cannot correct the bad...
There is no way to fix a bad sector. A bad sector is like a scratch on a cd that can't be fixed. You should run a program like "HD Tune", when you use a program what it does is it will read the disk and when it can't read a certain spot it marks it as a bad sector. After that the hard drive will move the data from the bad sector to a spare area of the hard drive. The spare area will store the data from a bad sector and will be usable like the old one. However if you get too many bad sectors you will run out of spares. When that happens your drive will crash.
You Can Try These Steps: Windows comes with a built-in hard disk utility software that scans your hard disk for errors and attempts to fix them.
  1. On My Computer, select the disk drive that you want to diagnose and repair.
  2. Right click on it and select Properties
  3. Go to Tools tab.
  4. Click on the "Check Now" button under "Error Checking Status".
  5. Depending up on your choice, choose either "Automatically fix file system errors" or "Scan for and Attempt Recovery of Bad Sectors."
  6. Then click on Start.
Jul 10, 2011 | Toshiba 640GB USB 20 Portable External...
My transcend storejet has bad sectors.. what should i do to prevent it from getting worst?.
These sectors can be fixed.
  1. For Windows
    • 1 Double-click on My Computer to open the My Computer window.
    • 2 Select the disk that you want to diagnose and repair.
    • 3 Choose Properties from the File menu. You should see the Properties window for the drive that you selected.
    • 4 Choose the Tools tab.
    • 5 Click the Check Now button under Error Checking Status.
    • 6 Depending on your version of Windows, choose either "Thorough" or "Scan for and Attempt Recovery of Bad Sectors."
    • 7 Click on Start.
Read more: How to Fix Bad Sectors on a Hard Disk ' eHow.com http://www.ehow.com/how_113636_fix-sectors-hardfix-sectors-hard.html#ixzz1PeS42ET5
Jun 18, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Unistalled ext hd unsafely, now not being recognized.
It could be that the "table of contents" on the external disk-drive has been scrambled. Whatever you _do_ try, do _NOT_ try to run 'CHKDSK' (or "check disk") against the drive.
Instead, look online for "File Scavenger" software, which can read through the drive, sector by sector, and try to "stitch" together the pieces, in order to "recover" your files.
Jul 03, 2010 | Western Digital My Book Home Edition 500...
Sony Vaio VGNNR330E laptop wont start up right even after recover
I think you may have bad sectors on the hard drive which is why it loads the software but then when it comes time for the system to read it, it just hangs cause it can't read into the sectors on the hard drive.
Best way to determine this, try another known good working hard drive and if it goes thru all the way and loads then you know the original hard drive is bad.
Jun 17, 2009 | Sony Computers & Internet
After factory recovery sytem wont boot
Hi, there is a good possibility your hard drive has some bad sectors, I recommend downloading a utility that will check the state of the hard drive. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
You will need to burn the ISO on a working computer, then boot from cd and run the long test. If there is bad sectors the hard dive test will fail, then hard drive would need to be replaced. Good luck!
May 22, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
I have issues while transferring files back from Western Digital 1TB external drive. I copied all my important files there. In explorer all files are showing, but have issue, when you want to open or copy...
Hard drive may be going south and there may be bad sectors on it. Run WD diagnostic program on it and cross your fingers. Do not format the drive - that will erase all. If you do find bad sectors the check disk program will find and block bad sectors and move data in bad sectors to good ones whenever possible. After that you can recover as much as you can but not all because there will be areas where nothing can be read at all depending on the severity of the damage to the sector.
Sep 12, 2017 | Western Digital MY BOOK HOME 1TB EXT...
Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
228 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
