Question about Philips 64P8341 64" Rear Projection Television
Philips 4 blink error
I have a 42" Philips plasma tv. It blinks 4 times and pauses then blinks again. What does a 4 blink error mean?
    New Friend:
We unplugged the tv for 2 minutes. Plugged it back in, turned it on- had to press the on button twice. I am now watching the tv.
Posted on Jan 23, 2013
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: blinking power light
General IIC error. An experienced technician will have to repairthat problem, as you need specialized equipment.
Posted on May 04, 2008
larrygator
  • 8 Answers
SOURCE: philips 64P8341 power blinks 6 times
It could be time for a new lamp. Your manual should give you this "error code"
Posted on Dec 08, 2008
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
My panasonic plasma tv has some error! the red led bliks 7 times then pause and then 7 blinks again. what i can do? panasonic th-42pz70e
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Sep 12, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Red light blinking
You have a bad main board most likely. You can try unpluging it for 5 minutes.
Sep 03, 2009 | Philips 42PF9631D 42 in. Plasma Television
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 20, 2009 | Televison & Video
Philips 42pf5521d - no picture, blinking green light
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Aug 17, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Power problem for phillips 42 plasma 42pf7321d/37
That blink don't mean nothing. Measurements need to be made. Don't just buy the board troble shooting would need to be done to see witch board is bad. Also look on the fron of the set and see how many time the led flashes. That wher your error code comes from..
Four red flashes
if 4 blinks is consistent and even after unplugging tv still does not power on would recommend replacing small signal board as error is i2c communication failure which is specific to microprocessor located on small signal board
Jul 21, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 64P8341 64" Rear Projection Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
