Question about TruTech PLV16190 Television
TRUTECH PLV16190 Capacitor replacement what type
Black screen and no sound. On the TURTECH PLV16190 how can I find out the type of capacitor I need, is there a part number or something.
  • May 11, 2010
    Capacitors have their value, voltage rating and polarity marked right on them, and all you need to do is get a replacement with the same values. But what makes you think your dead TV is just a capacitor? How did you determine that?
    Champion:
  • 367 Answers
I take it there is a bad capacitor on the inverter?The board that powers up the lights for the screen.Any bad ones on the power board as well?The two PLV16190 I fixed had bad capacitors on both boards.Usually the tops,and or bottoms bulge out when they go bad.When you do go to replace them,you can get ones with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF,and a 16V 1000 UF,you can replace them both with 16V 1000UF,and it will work perfect.You can also use different heights as well,as long as there is enough room.The type you want are called Aluminum Electrolytic.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on Feb 26, 2009
TRUTECH TV DOES NOT TURN ON. THE LIGHT GOES OUT BUT TV DOES NOT TURN ON
I just had the same problem this morning, but my monitor is now up and running. First, I tried unplugging from the wall for a long time to discharge any capacitance - still didn't work. Next, I took the back of the TV apart and reseated connectors - stll no good. Next, I unscrewed the power board and replaced the main large inlet capacitor - still no good. Finally, I was about to throw it out the window when I decided to reflow the solder on the main controller board using my hot air gun. Yes, it worked and is working right now! I would not advise doing a hot air reflow unless you are ready to throw it in the garbage. Explanation: Solder joints can become stressed, (seems like it happens a lot when the weather gets colder) sometimes causing them to split or fracture. By heating up the solder, you allow the cracked joints to reflow and rejoin once again making good electrical connection.
Jan 08, 2010 | TruTech PLV16190 Television
I have a Truetech PLV16190 Flatscreen. Problem: Screen Black (no picture)but sound work fine. Any solutions for this problem? ralphw4606
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Feb 18, 2009 | TruTech PLV16190 Television
Trutech 16190 no remote
Try the Universal remote control URC-R6 it works fine with my Truetech.
The bad thing about my Truetech PLV16190 19" Flatscreen, 30days after I purchase the remote the tv went out. Screen Black, but sound works fine.
Feb 05, 2009 | TruTech PLV16190 Television
NOTHING COMES ON
Open the back of the TV,and look at the can shaped items called capacitors on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.Most of the time the big black capacitor on the power board goes bad,and bottom bulges out,but sometimes it is the other capacitors as well.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Jan 27, 2009 | TruTech PLV16190 Television
Black screen
They are called capacitors.You have to unsolder the bad ones,and solder in the new ones.Have you removed the back of the TV yet?I hope this helps.If you have any other questions,please let me know.Thank You very much! Tyler
Jul 16, 2008 | TruTech PLV16190 Television
TruTech PLV16190
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Jun 03, 2008 | TruTech PLV16190 Television
TruTech PLV16190 no picture, no sound
Very likely have blown fuses and capacitors in both the power supply and the backlight inverter sections. Repair is best left to a technician unless you are tech savy and able to use a soldering iron.
May 03, 2008 | TruTech PLV16190 Television
No picture
Probably a faulty backlight inverter circuit. This circuit usually has two blown capacitors that will need to be replaced and their failure can sometimes lead to the failure of a capacitor in the low voltage section of the main power supply.
Apr 05, 2008 | TruTech PLV16190 Television
The official website for this item is http://1800customersupport.com/trutech. Try emailing them, or call them at 1-888-252-6252. Trutech is the store brand for Target stores, so many different companies make their products. This website isn't the official site for ALL Trutech products, just some of them, like this 19" LCD TV.
Jul 12, 2007 | TruTech PLV16190 Television
TruTech PLV16190 Television Logo
380 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
