Televison & Video Logo
joseph ulaszek Posted on Mar 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reprogram a RS5000 galaxy auto remote - Televison & Video
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 10, 2013
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14995014
Points
237762
Click here to download the user manual to your remote control. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Remote won't turn tv or change chamnnel
You need the instructions for remote to reprogram the tv to work
Normally holding POwer + TV will start an auto scan.
3helpful
How do I change the battery in keyless entry fob for a 1999 Oldsmobile alero?
REMOVE REMOTE BACK WHERE BATTERY GOES. TAKE TO ANY AUTO PARTS STORES OR WALMART ELECTRONICS.WHEN NEW BATTERY INSTALLED. YOU CAN TRY TO SYNCHRONIZATION TO REPROGRAM REMOTE.TRY THIS STAND 5 FT FROM VECHICLE.PRESS AND HOLD THE LOCK AND UNLOCK BUTTONS SIMULTANEOUSLY FOR 7 SECONDS.HORN CHIRPS TO CONFIRM SYNCHRONIZATION. IF THIS DONT WORK DEALERSHIP WILL HAVE TO REPROGRAM KEY REMOTE.
Keyless remote and auto start does not work, how can I reprogram
You cannot since you don't possess the $35,000 piece of equipment that the dealer possesses. Take ALL of you remotes to the dealer for a one time reprogram of all of them for about 40 bucks total.
I can't get channels bwyond 13 and remote is gone so I can't reprogram for other channels. Can this be done withour the remote?
hopefully you have a menu button on your TV, if so you should be able to access auto program (you might have to search to find the auto search)but before you auto program make sure you set your TV to a cable setting then auto program. If you do not have a menu button on the TV, you could also try buying a universal remote. If you don't want to do that you could always use a VCR, just set your TV on channel 3 and do a auto program on the VCR ,using the VCR remote you should be able to tune in the channels your missing through the VCR.
Auto start will not function
you will need to have the remote reprogrammed probably at the dealer
Reprogramming the factory remote starter on a 2008 Chevy Siverado
No, its a Auto-Anti-Theft Unit, your best bet would be to buy a $100 kit from auto zone. The Stick unit is built that way because if you start it and walk away, I can use a blank key to unlock the ignition and drive off.
2helpful
AKia pdp-4249g
I HAVE PROBLEM,THE SCREEN SAYS AUTO SELECT SEARCHING,THEN NO SIGNAL FOUND THEN THE TV TURNS OFF BY ITSELF
2answers
Auto start
did you install yourself and what module did you use for the doorlocks or did you have it installed at a shop
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
