Question about Marshall Mg100dfx 100-Watt Combo Guitar Amplifier
Something has blown?
My marshall vs232 amp is a good few years old and i think it has blown! there was a slight bit of smoke coming out of it when it happened! the power LED comes on now but no sound comes out! what could have possibly blown? do you think it would be expensive to get fixed? should i just throw it away?
  • 4,234 Answers
The output transistors may have shorted and caused a resistor to smoke (literally!!). This should not be too expensive a repair for anyone that works on these amps. Figure on $20-$30 for parts.
Dan
Posted on Feb 23, 2009
Blown filter capacitors
What model amp do you have?
Apr 25, 2014 | Marshall Music
Unresponsive Acoustic channel 2 Marshall as100d ....
I have same problem. i have this map. please help me to find the problem. if you can point the area in this map that problem is from that.
Mar 04, 2013 | Marshall Amplification Marshall AS100D 2x8...
6 th string 14-18 th fret buzzing coming out of the back of the amp reverb resonance presence all turned down brought it back where I got it they said it was all good
The problem MIGHT be with the guitar and this amp may be capable of presenting the sound from the guitar. Put a "fake fret" on the guitar... a piece of coathanger wire laid by the offending fret that will slightly raise the string for a test. Does it still buzz with the strings slightly higher, but at same tone... Note you might have to tune the strings SLIGHTLY with this fake fret to get on exactly the same pitch as using the normal fret... If the amp still buzzes with teh strings in no way creating the buzz, the problem is likely something in the cabinetry or chassis that is resonating at that pitch.
Apr 22, 2011 | Marshall Amplification Marshall MA100C MA...
Every time i turn on their is a loud high pitch squeel that occurs on my Marshall VS232 amp. My volume is all the way down, and the gain channel isnt on either. What is the problem?
If this happens when guitar cable is disconnected, take unit in for repair. This should be easy to troubleshoot. Hint: demonstrate the problem in the shop. Things have a way of fixing themselves and then lots of time is wasted trying to recreate the problem.
Mar 14, 2011 | Marshall Amplification Marshall Haze...
My Marshall mg100hdfx is a little over 2 years old and i never used it that much. I turned it on, made a popping noise and shut down. No smoke but i could smell a slight electrical burn smell. I never...
DO NOT try to use it until it is repaired or you may do further damage. Probably a capacitor shorted or a diode in the power supply. This is NOT DIY unless you are competent at electronic repair. When it is appeared to be restored, put a 150 watt lamp in series with the power cord to limit current till you know it is repaired... saves fuses and destroying further components if there are other parts that are bad.
Nov 03, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Vs232 has power and makes noise when you plug in to input but no output
Check that you have 15 volts across C19 and C20.
If either are bad, suspect ZD1 and ZD2 regulating Zener diodes.
Check the soldering and condition of the input jack as these are chronically bad due to damage of yanked cords.
Apr 25, 2010 | Marshall 15 Watt Guitar Amp
Smoking marshall vs232
If you got smoke and now it is making wierd sounds then it is fried. DO NOT turn it on until it gets seen by a repairman, unless you think fire is a good thing =)
Aug 09, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall MG10 cd guitar amp picks up radio frequency?
First of all I would call the radio station and let the know that there over modulating just a bit.this has happened to me a few times even on my tel/phone. I use to get WOKO on my amp. You can try and move the amp to diffrent location , reverce the polarty switch on the back , not much more you can do. But watch out when you here music comming from you toster your in big trouble, just kidding. Good luck DFD
Apr 13, 2009 | Marshall MG10CD 10 Watt Combo Amplifier
I have a Marshall MG50DFX. It's about 2 years old. I took it out on a gig and it quit working. The fan still works, but no sound. This amp is practically brand new. I am very diassappointed with the...
Hi a couple of years back I had a similar problem. Remove the chassis, you will see a wire (might be blue) it is quite noticeable (looks like a jumper a few inches long). It controls channel switching. Check it for dry solder or broken at either end. Good luck, Dereeldeel
Jan 16, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall Mg100dfx 100-Watt Combo Guitar Amplifier Logo
183 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
