Question about Uniden Cordless Phone
My phone no longer rings.
The screen lights up when someone calls and displays the caller ID but no sound comes out. I went into menu and turned the volume all the way up but there is still a music note on the main screen with a slash through it and no sound.
I have that problem every couple of months. What I did was unplugged the power from the answering machine for about 25 seconds and plugged it back in and then it was fine.
Posted on Mar 08, 2009
When phone rings it used to announce the caller ID, but now it doesn't.
Hi Steve
Find "Caller ID"
Press the phone icon.
Press the menu icon.
Press Call settings.
Press Additional call settings.
After a moment the current settings are displayed.
Press Caller ID. Turn your own caller identification on or off
Press Hide number or Show number. Return to the home screen
Press the home icon to return to the home screen.
May 10, 2016 | LG G3 VS985 32GB Verizon wireless CDMA /...
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Each time a call comes through, it audible states: verizon wireless. Went to the verizon shop today and less than helpful person went into sounds settings and put it on "ring only" in caller id readout. ...
You need to go to the Menu option and than go to Sounds, Go to Service Alerts and than go to Call Connect and turn that to Off and go to ERI and turn that to Off. That should solve your problem.
Jun 04, 2010 | LG CHOCOLATE VX8500 Cellular Phone
I have a Nokia e71, and everytime I call someone the caller ID on the person's phone says "private caller". How can I change this?
Telephone settings
Select Menu > Tools > Settings > Phone.
Select from the following:
• Call — Define general call settings.
Call settings
To display your phone number to the person you are
calling, select Call > Send my caller ID > Yes. To let
the network determine whether your caller ID is sent,
select Set by network.
Nov 13, 2009 | Nokia E71 Smartphone
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Mar 07, 2008 | Uniden 5.8GHz Cordless Phone
Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Mar 06, 2008 | Vtech ia5864 Cordless Phone
Caller id
This is a feature from your phone company you may have to pay extra for. Caller ID information is normally transmitted just after the first ring. When you are using call waiting there is no ring.
Jun 19, 2007 | Uniden DCX640 Cordless Expansion Handset
Uniden Cordless Phone Logo
65 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
