Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Samsung TV won't turn on when I push the button on the remote or on the TV itself. The Model Number for the TV is LN32A450C1DXZA
Sounds like the infamous capacitor problem! File a complaint with the BBB (like I just did) and then write Samsung Electronics America and complain to them (as I will be doing soon). Others are blogging that they have had success in getting Samsung to pay for repairs. Here's their address:
105 Challenger Rd.
Ridgefield Park, NJ
07660
United States (Map)
Phone: 973-601-6000
Fax: 973-601-6001
Toll Free: 800-726-7864
Posted on Dec 03, 2010
Samsung remote manual
when pushing the guide button on samsung tv remote i get "do you want to stop recording and use this instead" but its not recording anything any idea how to fix this so i can get my tv guide up
Jan 14, 2014 | Samsung Televison & Video
Samsung factory reset
Check the buttons on the tv itself and make sure the volume up button is not stuck. Samsung.com is not showing a tv with that model number. There may be a software update for that tv so check the model number again and check their site.
Dec 10, 2013 | Cell Phones
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
My toshiba tv model 32yt56b2 turns itself on and off continuously after i push the on button on the tv until i press the off button again
Check the microswitches inside the front panel control. You have to take the front panel control printed circuit board out from the TV. Repalce all the microswitches there at one time. It won't cost mor, and can be bought from most of the electronic spare part selling shops at your town.
May 17, 2012 | Televison & Video
My remote will not turn the tv on it work for about a week. I have replaced the batteries numerous times with no help
Can another remote turn on and off the TV? Do the buttons on the TV itself work (assuming a front panel lock isn't engaged)? Is this the original remote for the TV or a universal remote?
The possibilities: 1) The remote has failed. If you have a digital camera, take a picture of the IR side of the remote when someone presses the buttons. When you review the picture, you should see a bright spot in the picture. This indicates the remote is at least sending a signal. Sometimes the buttons will fail to make contact with the circuitry of the remote (due to wear). Other times the IR transmitter fails (the suspect if there is no light in the pictures from multiple button presses of the less used buttons). It's cheaper to replace the remote than it is to repair it.
2) The remote has lost the code for the TV. If you have a universal remote, try reprogramming it. (Cable or Satellite controllers count in this group).
3) The IR receiver on the TV has failed (if the buttons on the TV work) or the entire board has failed. You can get replacements for these at some sites. Try shopjimmy.com (minimally used parts) or partstore.com. You will need to open the TV and get the part number for your individual model for best results.
4) The TV won't turn on due to power supply problems.
If you need a replacement remote, a universal remote should work but the low end ones may not access all of the features of the original. Check for buttons that match features like Menu and Source (Input) if your TV doesn't have equivalent buttons on the TV itself. The remotes that are programmed via a USB connection with a computer are the easiest universal remotes to set up. If you want the original remote (or a close substitute that will perform all of the original features), first check if a parts store exists for your TV manufacturer (Samsung for example). Next try remotes.com and search for the TV model (leave out the manufacturer).
I hope this helps.
Apr 19, 2011 | Televison & Video
Hi, I have a samsung le32r74bdx lcd tv and the volume has just gone to 100 and i can't turn it down?
First, start by unplugging set to try to reset. Then make sure that all settings in audio menu are correct. Also look for stuck volume up button on set and on remote. Sometimes buttons get lodged under surrounding frame. Also try to push volume down button on tv and watch for display on tv to see any change. If when you release button volume increases by itself, remove batteries from remote to eliminate it as cause. If nothing you try works expect to replace main pcb. You can probably price it online with model number. Good luck, Russmann.
Jun 09, 2008 | Samsung Televison & Video
Making my SIR-T451 remote work with my Zenith TV.
Push the Set button and enter the following codes and enter one of theese codes: 018, 020, 193. If one doesn't work try the next one. You have to push set each time you enter a new code.
Jan 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
956 people viewed this question
Henry  Thomas
Henry Thomas
