Question about Farberware Stanley Power Return Tape Measure 12 ft x and a half''w wBelt Clip
Need info on teturning tapes under warrenty
Need info on returning tape measures i feel should be under warrenty
    Champion:
  • 225 Answers
Stanley tapes are life time warranty take it back where you bought it they should replace it.
Posted on May 31, 2009
  • 2 more comments
  • shane covert May 31, 2009
    stanley tapes are life time warranty take it back where you bought it they should replace it.
How to rewind a tape measure
You'll need to take the tape casing apart but need special security torx bits to do that (a T-8 and T-9). Once apart (careful, two small springs inside) you can take the tape spool apart and rewind the tape to re-establish tension. Then re-assemble!
May 08, 2014 | Black & Decker Auto Tape Measure
I purchase a Lufkin tape measure and now the tape will only extend out 18" and no further. I have checked and the "lock" button is not on. How do I go about getting this replaced? I use this tape...
When you pull it out eightteen inches, does it feel like it's under tension like normal? Is it retracting like normal? If so pull it out hard, in a quick tug, you probably got something in it. It's just bound.
Sep 18, 2013 | Hand Tools
I have a Stanley Power Lock 30' Tape Measure with 2' 9" of tape that I cannot get back into the housing, Is there an easy solution to this problem? Advise and thanks,
you can try to pull the tape all the way out and then with a rag lightly oiled let the tape rewind back into the housing if that does not work then you probably need to purchase a new tape. for whatever reasona the spring inside has gotten weak. i use a tape daily and have had this same problem when a tape gets old or abused
Feb 11, 2011 | Stanley 30-305 HI VIS MEASURING TAPE
Tape broke on W928 tape measure
I looked around and can't find a replacement tape for this 12 footer. The tape measure itself seems to be no longer available.
I suggest recycling it and buying a new tape measure.
Jan 06, 2011 | Lufkin 8ftx1/2in Tape Rule W928
How to read steel tape?
Not enough info, a steel ruler could be in 64's of an inch, a steel tape measure is usually in 16's of an inch but some are in 32's of an inch until you get past the 12" mark.
Oct 05, 2009 | Peachtree Woodworking 12' LEFT READING...
Can't get the tape to eject. Any suggestions?
The tape is caught in the pulley system. It happens on the older players at work. You can eject the tape manually to get it out but you will have to break it to do that. Best to replace it with a new one. If it is under warrenty, get it replaced.
Aug 09, 2009 | Televison & Video
Adress needed
United States
Canada
Stanley Tools
1000 Stanley Drive
Concord, NC 28027
Attn: Quality Assurance
Stanley Canada
1170 Invicta Drive
Oakville, Ontario L6H 6G1
Feb 23, 2009 | Farberware Stanley Power Return Tape...
Problems with clean led
This is either a sign that your tape drive is bad or it is time to get a new cleaning tape. Find out if it is covered under warrenty first i have had problems with tape drives on the model in the past.
Jan 14, 2009 | Dell PowerEdge 1800 Server
How to fix a stanley power-lock 25 ft measuring tape
Take the four corner screws out and the last center (short screw out). Split the shells in two pieces. Seperate the yellow or measureing tape from the black spindle tape. The spindle tape holds or attaches the measurement tap to the spindle. I have only seen a plastic spindle and this tutorial only applies to the plastic one. Take the spindle out and set the half casings on their backs, so you can see the cavity of the shells. The black spindle tape will be preformed to only wrap one way. Go ahead and attach the yello measuring tape to the black spindle tape. Pay close attention which side of the yellow tape is facing up or in our intended direction which is towards the center of the spindle. This way when you pull the tape out it is facing up for the person can see the measure marks. Wrap the tape tightly. If the tabs are broke and there's no way to secure the Yellow to the black, use two strips of Duct Tape and adhere the sections together. Do not use too much tape, since the clearance inside the spindle is tight. Once you wrap the tape inside, put a temporary piece of tape to secure the yellow and keep it from unraveling again. Next take a 1" wood screw and a battery powered drill and insert the screw into the center of the plastic spindle. Slowly tap the screw until it catches, do not drill the screw all the way in, only enough to catch in the plastic. Once the screw is partly into the plastic place the spindle into one of the half shells. The reason for the drill and screw is to return the tension back to the internal spring. Whichever side you placed the screw into you need to be sure to apply a clockwise turn. Keep the hex head of the drill so to not release the tension. At the same time place the spindle in the half shell and lock its square center piece into the shell. Now you can remove the screw from the center, then remove the tape holding the yellow meauring tape down, Still holding the measuring tape so it wont unravel, begin placing the last half shell on. Obviously you need to line everything up so the tape slides freely through its opening. Align the tape slide stop, which rests between the two shell halves. Replace the screws and remember the short one goes in the middle and holds down the belt clip.
Frank
Jan 03, 2009 | Stanley 30-305 HI VIS MEASURING TAPE
Quantum Superloader remove jammed tape
You have to disassemble the unit and remove the tape. Chances are it's stuck in the carousel (the round thing at the front that spins tapes and plugs them into the drive).
May 06, 2008 | Quantum ATL SuperLoader Ultrium Tape Drive
Farberware Stanley Power Return Tape Measure 12 ft x and a half''w wBelt Clip Logo
164 people viewed this question
Top Farberware Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Farberware Measuring Tool and Sensor Expert? Answer questions, earn points and help others
