My Philips DVD-player comes up with a strange error-message writing "Blocked" in the display and then it stops playing. All this happens within the first 5 seconds after loading.
you can try to enter 0911 as a reset coad or 0711.
hope this helps
Solution #2
posted on Aug 02, 2007
Lizzy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
"Biz" < ...
<SNIP Well in Denmark Philips is very difficult to contact. No phonenumbers, no e-mail adresses etc. I will try Philips, Holland.
Thanks!!
Greetings, Torben, Denmark.
Was this helpful?
Yes
No
Solution #3
Powe33 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
If the master reset code is not in the manual, contact Philips support...
Was this helpful?
Yes
No
Solution #4
pawa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
"Pat Horridge" <p@remove-spam.vet.co.uk ...
Dear Pat! Thank you for your quick response! Maybe you are on the right track but I don't recall that I ever typed in a 4-number code to block the machine! The procedure is described in the users manual but maybe the player went into a block-mode by "accident". You never know what happens when you are dealing with microcomputerbased equipment, hehe.
Do you know of any "master-reset" procedure?
Greetings, Torben
Was this helpful?
Yes
No
Solution #5
Grant - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I would image it's eitehr a Region problem or a parental level problem. Ensure the region DVD matches the Region of your DVD player. Also check the parental rating level within the DVD player is not active or set to 18
DVD recorder .Whenever a disc is loaded it says NO-READ even lense cleaner or pre recorded discs are...
(More)
DVD recorder .Whenever a disc is loaded it says NO-READ even lense cleaner or pre recorded discs are the same The display shows a disc is loaded even if there is nothing in the machine.During recording the recording just stopped and there was a problem removing the disc,then the problems above started to occur.Help!!! need the machine for Christmas.
I have a Phylips Kitchen CD clock radio unit. I have had it for about 1.5 years. This problem...
(More)
I have a Phylips Kitchen CD clock radio unit. I have had it for about 1.5 years. This problem started suddenly. While playing a CD, it freezes momentarily, then continues. It happens with any CD. I have used a cleaner disc and it is no better.
I have a philips dvd612 player and for some strange reason every time i turn it opn the tray opens...
(More)
I have a philips dvd612 player and for some strange reason every time i turn it opn the tray opens and it says blocked on the display window. What has gone wrong??
