Question about Lexmark X5495 Printer
Bought #32 ink for X5410 and it says left cartridge incorrect.
Even though it says that, on the box of the cartridge it says that it's compatible with the x5400 series. So i don't know what's wrong.
I had same problem. Even though box states this is correct cartridge, the x5410 actually takes ink cartridge 28/29.
Hope this helps.
Very inconvenient to have to exchange the cartridges.
Posted on Mar 05, 2009
Reset ink
This model printer may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
This means you need to purchase and install genuine printer cartridges.
May 05, 2013 | HEWLETT-PACKARD Hewlett Packard Deskjet...
I bought my HP Photosmart C6280 in Switzerland, using cartridges 363. Now I have moved to South Africa and I can only buy cartridges 177. When I put them into my printer it says "Incorrect Ink...
it is likely that you havr a mix of trade and host supply of ink cartridges. Even though HP363 and HP177 are compatible cartridges it is not the issue. Refer this article.
Hope this helps.
May 18, 2011 | HP Photosmart C6280 Printer
C 3180 hp printer, just bought from thrift store, ----but,,,it seems the thing that holds the ink cartridges is stuck, though its trying to slide as it should, it seems to be hitting,jamming , light re;...
First of all, if the ink cartridges are stuck, as you rightly guessed, it may not be the correct cartridge.
Now, even suppose, it is the correct cartridge, it would not have been installed correctly . the Label side of the cartridge should face upwards, Not towards you.. when you are inserting the ink cartridge.
if you are from India the compatible ink cartridge would be HP 850(BLACK) AND HP 855(COLOR)
In North,South America it is HP 92(BLACK) AND HP 93.
Aug 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
My Lexmark X5410 Printer will not recognize a refill cartridge.
Hi there
This is the same old story with Lexmark printers, you cant do any thing about it the chips have a small fuse inside them and soon as they emty it blows the fuse, and thats it so I beleave the only way is to buy new ink, or a diferent printer.
Not know any fix for them myself sorry.
Can try.
Turn printer off. Unplug power cord and other cables. Wait 30 seconds. Plug cords and cables back in.
Also seen this on the net.
Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
but yeah, best bet, never ever buy lexmark.....:)
http://www.fixyourownprinter.com/forums/inkjet/35235
If that doesn't work, try disabling your ink monitoring software.
All The Best Pineworks
Feb 21, 2010 | Lexmark X5470 All-In-One InkJet Printer
Black 32 cartridge not working in X5410 printer
Did you purchase a "Lexmark" factory new cartridge or was it a third party cartridge made for a Lexmark printer.
The Black 32 Cartridge is listed for the family of printers. So either you have a defective cartridge (Contact Lexmark and ask for a warranty exchange of the cartridge) or return the cartridge to the store you bought it from and tell them your problem.
Jul 13, 2009 | Office Equipment & Supplies
Cartridges #32 and #33 are not being accepted
are they genuin lexmark cartridges or knockoffs? could be the printhead being clogged up aswell..if you can pull out the printhead (where the cartridges dock), see if theres gunk..if there is, carfully clean it...you can spray windex on a papertowel and let it sit on it overnight and it will allow it to be cleaned.
Apr 26, 2009 | Office Equipment & Supplies
I have an X5410 Lexmark printer and I'm trying to put in a black ink cartridge # 32 (It said this one is compatible with the printer) Every time I close it it says that the left cartridge is wrong. I...
Looks like the #32 and #33 are not compatible with x5410. Check this link for cartridges that will work with your specific model: http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
On step1 - "Choose your printer type", select "All in one"
On step 2 - "Choose your printer model" select "Lexmark x5410"
On step 3 - see the list of compatible cartridges.
If you bought the cartridges from the store see if they will replace it for you. If that doesn't work try calling Lexmark customer support.
Good luck.
Feb 23, 2009 | Lexmark X5495 Printer
The catridges are put in correct places,but when i give a print
I had that problem with my Lexmark X5410. The cartridge box
said it worked in the X5410 but the instructions gave a different
number cartridge to use. The #32 cartridge was not right for my computer. It needed a #28 Black.
Also - make sure you remove the tape from the cartridge before installing it.
Good luck
Jan 17, 2009 | HP Officejet 4355 All-In-One InkJet...
Left Cartidge incorrect
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Jul 08, 2008 | Dell 922 All-In-One InkJet Printer
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X5495 Printer Logo
330 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
