Question about Verbatim (95209)
Wireless mouse button configuring
I can't configure the scroll button on my wireless mouse (windows Vista). I want to use the scroll button for doubleclick
Extra buttons on mouse dont work
if you are not an electronic geek that can tinker with these devices, you already have a faulty mouse, no wireless connection issues may occur. Or you may need to reset the mouse and the computer , then try re configuring your wireless mouse, sometimes software loaded on your system disrupts the mouse settings or are incompatible with the mouse.
Dec 28, 2013 | Onn Wireless Mouse M730r W/ Blue Optical...
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
Intellinet wireless adapter malfunction
Wireless Zero Configuration (WZC) was introduced with Windows XP, it is also known as WLAN AutoConfig in Windows 7 and Vista. It is is a wireless connection management utility which dynamically selects a wireless network to connect to based on a user's preferences and various default settings. or most users the Windows Wireless Zero Utility is all that is needed to manage your wireless connections.
You can configure WZC as follows:
  1. Type services.msc in "run" and enter.
  2. Select wireless zero configuration from the list which appears in the next window.
  3. Double click on that option , and choose to Start or Stop the Wireless Zero service.
Here are steps to use Wireless Zero Configuration/WLAN AutoConfig in Windows 7:
  1. Click the Windows logo button
  2. Type services in the Start Menu's Search box and press Enter. Scroll to the bottom of the list and locate WLAN AutoConfig'. Double-click WLAN AutoConfig to open its Properties window.
  3. Click the General tab of WLAN AutoConfig service. Click the Startup type drop-down menu and click Automatic to have the service started automatically when the operating system loads. Click the Start button. Click Apply and then OK. Close the Services console window.
  4. Click the Windows logo button. Type cmd in the Search box and press Enter. In the Command Prompt window, type netsh wlan show settings and press Enter. Look at the last line of the Wireless LAN Settings entry to see if the message Auto configuration logic is enabled on interface or Auto configuration logic is disabled on interface appears. If the entry notes that it is disabled, type, set autoconfig enabled=yes interface=Interface Name and press Enter. Close the Command Prompt window.
Nov 25, 2011 | INTELLINET Wireless 150N USB Adapter...
How do you program the side buttons on the mouse
In general you can get the settings of the mouse by going in to..
For windows XP users:
  1. Click on start > control panel
  2. Under control panel look for printers and other hardware.
  3. It will ask you to pick a task.
  4. Click on "mouse"
  5. Then go ahead and configure the settings that you want.
For windows vista users:
  2. Go to hardware and sound
  3. Look for mouse, click on it.
  4. Then go ahead and configure the settings that you want.
For windows 7 users: (same options for win vista)
Congrats! :)
Feb 02, 2011 | Office Equipment & Supplies
Pleomax laser mouse doubleclick not recognised with centre button
You need to have a driver for your mouse to operate windows 7 normally. Obtain the driver from its official website. Windows 7 is new that is why there are some many hardwares are yet to be compatible for it.
Dec 23, 2009 | Samsung Pleomax SCM-9000 Mouse
Need Mouse Driver for Mac Leopard
Without the drivers the mouse runs great. The only thing you can't do is use the second scroll wheel to scroll left and right. Instead the mouse scrolls in the opposite direction than the first scroll wheel. The side buttons can be configured within OSX and Windows for whatever you might want.
Aug 21, 2009 | GE 97985 Mouse
Zero wireless configuration has been disabled on presario
Follow this procedure to stop and start the Wireless Zero Configuration service in the Windows XP Operating System:
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type cmd .
  3. Press the ENTER key.
  4. In the Command Prompt window, type net stop wzcsvc .
  5. In the Command Prompt window, type sc config wzcsvc start= auto .
  6. Press the ENTER key. NOTE: The [SC] ChangeServiceConfig SUCCESS should be displayed.
  7. Type net start wzcsvc .
  8. Press the ENTER key. NOTE: The Wireless Zero Configuration service was started successfully message should be displayed.
  9. Type exit .
  10. Press the ENTER key.
Jul 29, 2009 | HP Computers & Internet
Centrios X7 gaming mouse
It should work on Vista 32-bit. It says explicitly in the manual that it WILL NOT work with 64-bit Vista. I think you're out of luck, dude.
Aug 29, 2008 | Computers & Internet
Erratic mouse
did you uninstall old drivers first
also check for virus some viruses stuff up mouse operation
Jul 24, 2008 | Logitech Cordless Mouse
Verbatim (95209) Logo
26 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
