Question about Carrier Beverage Air® MT45-W-55 / MT45-B-55 Commercial Refrigerator
BeverageAir MT45 is running continuously. Its
BeverageAir MT45 is running continuously. Its loud.
The unit has not had regular maintenance for over a year. I cannot find a user manual online with serving specifications.
Any help out there?
Air Conditioning it is not cooling but the Fan keep working is it the control box
Air conditioning units in vehicles require regular maintenance to provide continued good service. Your unit may require a "recharge" Most garages will provide this service for about £40/50.
Jan 10, 2017 | Cars & Trucks
MT45 0705I02 R12 not cooling, motor in bottom not working as well.
I had the exact same problem. The condenser fan in the bottom should run all the time. The entire condenser unit (compressor, coils and fan) sit on a metal tray that may be rusted to the bottom of the unit so a few taps from a hammer from the back may be needed to slide it forward. Once you can get to the fan, check the wiring. On mine the spade plug had rusted away. Follow the wires from the fan to a small box on the side of the compressor. Make sure the fan wires are securely connected to the terminal block. There are two male spade connectors that provide constant 120v. They point up. Make sure there is power and the fan motor is connected.
Jun 11, 2012 | Beverage-Air MT45 Beverage Cooler...
The Compressor on my Maytag M7DH65B2A quit running, I brought it to my shop and noticed corrosion and an oily residue on the sensor with the metal clip. Looks like the corrosion caused a hole in the coil....
This is a common problem with most dehumidifiers, not matter who the manufacturer is. The best way to prevent it is routine maintenance. Especially when you stop using it for the season. Dismantle it and clean the unit thoroughly. Putting a light coat of WD40 on the coils and contacts will help abate corrosion during the off season. If you are in an area where you use the dehumidifier continuously , then you should step up your routine maintenance to every 6 months. Cleaning the filter regularly, will help expand the dehumidifiers life span. By the way, the model you listed was manufactured by Fedders for Maytag.
Keep up the routine maintenance.
Apr 06, 2011 | Maytag M7DH65B2A Dehumidifier
Unit powers up, lights work, motor is running but it is not getting cold. The unit was given to me. It is only 1 year old and it worked when I put it on the truck.
Beverage-Air are very good about helping the customer. Just be sure you don't leave out your serial number. The seem to get lost without that. Thanks, Sea Breeze
Nov 25, 2009 | Beverage-Air MT45 Beverage Cooler...
Manual, wicking pads/assembly
It holds 24 pads... all individually placed in
Sep 01, 2009 | Carrier Beverage Air® MT45-W-55 /...
Condenser bad?
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jun 03, 2009 | Beverage-Air DP46 Commercial Refrigerator
Motor
The condenser motor is a 9W
The evap motor is 503-088B
MANUAL pdf
Get your parts at partstown.com
Mar 11, 2009 | Beverage-Air MT45 Beverage Cooler...
Refrig compressor "knocks" when cycling off
could be a broken spring inside the compressor and would only make a noise as the compressor stops. nothing you can do about it. you would need to break open the compressor, replace the spring, weld it back, then charge it up again with refrigerant.
Feb 11, 2008 | Refrigerators
Carrier Beverage Air® MT45-W-55 / MT45-B-55 Commercial Refrigerator Logo
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
