Question about Kenmore Elite HE4 Electric Dryer
My washer is flashing sud...what do i do?
My washer is flashing "sud"...what do i do? I have a Kenmore Elite 4T washer....
  • 5,911 Answers
The following link explains the "SUD" error and how to correct:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
The error can be caused from obstructions in your drain pump (or lines) to using the wrong type (or too much) of detergent. Read through the link thoroughly and let me know what you find. This problem usually has a simple remedy that does not require a repairman. However, if you require additional assistance, or have questions, please let me know. I hope this helps you.
Posted on Feb 26, 2009
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Kenmore elite front load washer model 46752701 after replacing pressure control switch i still get f35 code
    Most common cause for the F35 error code: Using non-HE detergent. Detergent slime builds up in the hose, eventually getting into the analog pressure switch and killing it. Make sure you flush out as much soap as possible and make sure to use HE soap or it can keep occurring, also some vinger can calm down the suds
    Oct 26, 2013 | Kenmore Elite HE3 Steam 8674 Dryer
    Sud
    This is a Suds Detect error code. The following link explains the error and potential causes:
    http://www.fixya.com/support/r3608687-sud_error
    The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
    NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
    Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
    Read through the link provided and let me know if you still have questions. I hope this helps you.
    Apr 22, 2010 | Kenmore Elite HE4 Electric Dryer
    I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
    HI. this code represents a Long Drain issue.
    If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
    Press PAUSE/CANCEL twice to clear the display.
    NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
    Potential Causes
    • Check the drain hose and make sure it is not plugged or kinked
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects
    • If the above does not correct the problem replace the pump
    Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
    Want to stack my Kenmore HE4 Dryer on top of my Kenmore HE3t W/M
    When you originally ordered the dryer, it should've come with a stacking kit that is compatible with the HE 3T or HE 4T washer. It is basically a foam piece that goes on each side of the washer, and then the dryer is connected to it from the side. If you do not have this piece, it should be available to order if you visit http://www.searspartsdirect.com Just enter the model number from your dryer (inside the door frame) and it should pull up a parts list. Or just try searching for a stacking kit for Kenmore dryer. Hope this helps.
    May 18, 2009 | Kenmore Elite HE4 Electric Dryer
    My screen in showing code "dl" and then "f", please help?
    The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
    Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
    Kenmore Elite Oasis HE/ Error Code F1
    repl/ main control board reason for error code F 1 ,,,nothing else
    Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
    Kenmore Elite HE4t Washer
    WE had a person with the same problem with her HE4 front loaded washer. What we discovered was when we opened up the soap resivour was that soap built up around the float valves causing them to stick.
    A technician I knew put vinegar down the soap dispensor and ran the cycle, with the washer empty. He put it on in the hot water mode and ran it for four or five complete cycles like washing clothes.
    It worked for him. Try it like it did for him to see if it helps. If not, you will need to contact a service technician to see if the SUD error code means something else.
    Sometimes the timer boards get a bit of moisture on them and cause a corrosion headache. I have yet to see anyone figure out a way to dry them off, and when condensation builds up, it usually means there is a problem causing the condensation to get that far up. On some versions a foam seal gets worn out from time, often needs to be replaced to prevent moisture built up.
    Another thing that sometimes does it is the back of the machine, will be too close to the wall or have debris back behind there causing it not to be able to breath.
    May 14, 2008 | Kenmore Elite HE4 Electric Dryer
    Kenmore Elite Calypso Washer
    take the pannel off the bottom and unscrew the pump cleanout
    Feb 09, 2008 | Kenmore Elite HE4 Electric Dryer
    Kenmore Elite 4t
    This what to check for F/H code from repair manual.
    If the water is coming into machine, make sure drain hose is only sticking into drain pipe about 6 inches. Post back if you have any questions.
    No water detected entering machine or Pressure switch trip not detected.
    If after 30 seconds the control does not detect water entering machine and then
    valves will be turned off and the error code will be displayed.
    Or
    If the control has turned the water valves on and after 8 minutes the flow meter has
    detected 10.5 gallons of water passing through it, but has not detected the pressure
    switch trip, the valves will be turned off and the error code will flash.
    Potential Causes
    • If there is no water in the unit:
    • Make sure that both valves at the water source(s) are turned on all the way.
    • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    • Verify inlet valve operation
    • If there is water in the unit:
    • Verify Drain pump operation
    • Pressure Switch Hose is in good condition and properly connected to Tub and
    Pressure switch
    • Verify there is not a siphon problem
    • Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
    Flow Meter, and Central Control Unit (CCU)
    • Check all hoses for possible leaks
    • Verify pressure switch operation
    • Verify flow meter operation
    • Verify CCU operation
    Nov 07, 2007 | Kenmore Elite HE4 Electric Dryer
    Kenmore Elite HE4 Electric Dryer Logo
    103 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
