Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator double side GE
Is loosing cooling on both side and start to get defrost is working but not cooling inaf how i can fix the problem
  • Anonymous Mar 10, 2009
    same problem.. seems there was a recall for the mother panel.. call ge service an they will fill you in..
  • 74 Answers
Check the condensor fan is running at the back of the appliance and that the condensor is not clogged with fluff as a first course of action
Posted on Feb 26, 2009
Side by side GE TFT28PFBBWW freezer ok, refrigerator side cools interminently, most of the times does not cool at all
The problem is defrost.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer working fine but refrigerator not staying cold. If I unplug the unit and completely defrost and plug back in it works fine for a couple of days then starts to get warmer in the refrigerator. ...
Hi.
The self defrost system is defective. The parts comprised in the defrost system are the defrost timer, defrost thermostat, fan and heater. If the evaporator has separate coils for fridge and freezer (double evaporator), then there is also a three way valve that must be tested. Most refrigerators, even door-to-door have a single evaporator.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar with your model.
You can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE side by side w/Ice Denspenser. #TFX27ZP. Three times my frieg stopped working gradually. after removing everything it began to work again. I have tried to put minimal items in both the refrieg....
It seems as though your fridge is sticking in the defrost mode...try replacing the defrost timer/control...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | GE Refrigerators
I have a GE Side by Side Refrigerator. The
check your defrost heaters this is a common problem with ge ref you will have to take the back cover off you will see the heater towards the bottom some units have a double heater
Jul 03, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Nov 27, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
88 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
