Question about Logitech QuickCam Messenger Web Camera
I can't get camera to turn on. I think it's plugged in correctly
Posted on Feb 24, 2009
I have a GC-XA2BU and the camera will not cut on? I have purchased a replacement battery but neither work.
As soon as you connect a camera to a computer, it will stop working, because the USB connection will be used to charge the battery.
If your computer is not correct wired on the USB port, or when you are using a hub, without an external power supply, the battery will not be charged. So you end up with an empty battery and a camera that does not respond.
Try charging the battery on an external charger and remove the USB cable, before switching on the camera. Also check if the USB connector on the camera is free. Avoiding the camera to "think" there is still a USB cable connected.
Feb 11, 2014 | Cameras
I have a Finepix xp50, with a fully charged, correctly installed battery, that won't turn on. It worked intermittantly for awhile. We have 3 batteries for this camera thinking it was the battery
Be sure your battery is in the right way. Try reversing it. My battery has 3 rounded corners and one square corner. The square corner goes against the latch.
Aug 21, 2012 | Fuji Finepix F50FD Digital Camera
My camera wont turn on. There is a problem with the dv port. Would this keep it from charging? Because it wont charge and I think its because the dv port is messed up.
Your probably correct on this. I have a similar issue with my Sony and the camera dock. my charger works but I can't download the video from the camera because of the dock. Is there a DC in plug on the camera? mine has a small plug that is coverd in rubber on the back side and on the bottom. Look and see if you have this plug, you can just plug the wire going to the dock into the camera and charge it that way.
Mar 28, 2011 | Canon ZR100 Mini DV Digital Camcorder
Webcam for Lenovo 510 Y was reinstalled pside down. How do I correct the problem?
you mean the LCD panel was removed and the camera from the panel ?
whoever did that should correct it , don't you think so ?
are you sure it was installed upside down ?
do this -- turn computer on , and turn camera on
press ALT + CTRL and the down arrow
to revers the image press ALT + CTRL and the up arrow
does this help ?
if not get that camera placed the correct way
let me know if this helps
Nov 03, 2010 | Lenovo IdeaPad Y510 Notebook
Childs digital Camera will not do anything. Batteries are fine. When plugged to USB the camera screen shows USB but nothing else occurs. I took the batteries back out and plugged in the USB cord and had...
I don't know how old it is, but i would take the camera back to the store to try it on one of their computers. Just to rule out your computer settings. The store should have no problems; thinking if it doesn't work the salesman may get an easy sale out of you. Camera does need to be turned 'on' and in the correct mode for the computer to see it. If the computer never recognized the camera, you can download the camera's driver off the internet first.
Good luck
Jun 18, 2010 | Fisher-Price Kid Tough Digital Camera
My camera is broken.
Is the battery changeable, if so change the battery, if not you will probably need to plug the camera into the computer turn it on and let it charge up.
Apr 04, 2010 | Polaroid i735 Digital Camera
I have a FinePix A350 Fuji camera my software is for windows XP I have computer with windows Vista I think I need new drivers correct?
You shouldn't need ANY drivers. USB is native on both of these Operating Systems. Simply plug the camera into the computer and it should detect it without the installation of any drivers.
Jul 08, 2009 | Fuji FinePix A350 Digital Camera
Not uploading pictures
I think I know what the problem is, first off the computer must be able to communicate with the
camera/device irregardless of the drivers. The camera is plug and play and so is the computer
unless you are using an older version of windows like 98 or 98 second edition. If you are 98 etc load
the old drivers. But if you are 2000, millineum, or xp then the drivers are automatic for the usb ports.
The panasonic dmc-fz7 is kind of a freak in that it is not a true plug and play device. Sometimes
you have to declare the new hardware. It may have once worked but for what ever reason the hardware may not jive with what the pc thinks it sees if anything at all.
Solution: Go into the Control panel , add hardware wizard, with the camera hooked up to the usb
port and the camera turned on. In the device manager you should get the appropriate message, "new hardware detected" actually it should say dmc-fz7 etc. From there it should be apparent that things are working normally....Good luck. Probably a power glitch or who knows. Mostly its a problem with panasonic plug and play software which they corrected a year or so later with the newer cameras...
Dec 22, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Hi dikaya, my husband just bought this camera, where does the charger go? we cant seem to find where to plug it in on the camera at all? I think it must be a separate like docking station that just recharges the lithium battery? is that correct?
Apr 28, 2008 | iSonic SNAPBOX DV566 Digital Camera
Panasonic DMC-LZ2 Camera
shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens. Then open the camera and see if the ccd flex is correctly plugged in.
Jan 13, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Logitech QuickCam Messenger Web Camera Logo
22 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
