Can´t find driver
I´m loking for driver for this board dfI PE21-EC/EL
can you help me?
thanks
  • 31 Answers
Where do i plug in pwr led, H.D.D led and pwr switch?
Front Panel Connections of DFI AM35-EC Motherboard
DFI AM35-EC Manual (Refer Page 14)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | DFI AM35-EC Motherboard
I'm using DFI RDX200-CF DR motherboard this is support windows 7 OS ? In the DFI official website is not have motherboard driver for download to support OS windows 7. Please solve my ploblems.Thank you.
No, this board does not supports Win7 because ATI - the makers of the Xpress200 chipset - did not made a Win7 driver for it - they have considered the chipset too old for that.
Apr 03, 2011 | DFI LANParty UT RDX200 CF-DR Motherboard
I have no sound
Here are drivers for that board. Try new drivers
http://www.driverstart.com/start520070.html
Feb 07, 2011 | DFI PM12-EL Motherboard
Manualm and drive forDFI 661FX-MLV (e)
You can find the manual and drivers for download on DFI's site. The best place to go for this kind of stuff is always the manufacturer's Web site. In cases, where you can't find what you need on the suspected manufacturer Web site then you look somewhere else to download the data at no cost.
I'm positive that you will be happy with this solution. You will find a color image of the board along with its specs, drivers, manual, along with technical documentation...all in one place.
http://us.dfi.com.tw/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=&windowstate=normal&mode=view&downloadFlag=false&itemId=286
Please share your experience by rating this solution.
Thanks for using Fixya.
Mar 28, 2009 | DFI 661FX-MLVE Motherboard
My usb ports are not working the hardware finds them but they don
Check in CMOS the USB functionality is enabled, if it is, then get the chipset drivers for your motherboard and install, you can dowload this software from the motherboard's manufacturer.
Mar 18, 2009 | DFI AM35-EC Motherboard
New Vid Card, Comp Freezes when loading windows.
Fisrt you must Do a search online on how to make a deep uninstall of nvidia drivers.
Then...
Do "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove all ati or powercolor related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from the power color manufacturer that are available for your card.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are DONE!
Dec 27, 2008 | Power Color RADEON HD 2600 XT, Graphic...
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
DFI AK74-EC motherboard CD drivers
hey,
Here are the drivers:
VIA Service Pack 4.24
http://www.dfi.com/download/MOTHERBOARD_DRIVER/MB055VSP.ZIP
VIA Audio Drivers
http://www.dfi.com/download/MOTHERBOARD_DRIVER/MB055VAD.ZIP
VIA Hardware Monitor
http://www.dfi.com/download/MOTHERBOARD_DRIVER/MB055HWM.ZIP
If these don't work please contact me for more assistance we will find the correct drivers in no time :-)
Feb 11, 2008 | DFI AK74-SC Motherboard
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
