Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 3200 says raw in computer management
The harddrive was working great and then i moved the drive and now the computer finds it but it says that it is corrupt and unreadable and in my device manager it says that the drive is RAW. i don't want to format it because there is alot of stuff on it that i need. what is it that i can do to fix it.
  • 2 more comments
  • robie8404 Feb 23, 2009
    no the light on it stay solid and it is seen in my computer but nothing else.
  • jk620l Mar 19, 2009
    I have the same problem with my Maxtor 3200. I tried different recovery programs, and they didn't work. I then tried doing a system restore and that worked.
  • Dick
    Dick May 11, 2010
    Your question has already been answered in the other one you posted.
  • elwayman02
    elwayman02 May 11, 2010
    Is your drive making any strange sounds when it's running?
    Problem Solver:
  • 7 Answers
When your drive is in RAW format, the best thing you can do is try to recover the files and then get the hard drive replaced. I would recommend trying the trial version of this program: http://www.recovermyfiles.com
If that doesn't work, let me know, and I'll see if I can come up with another way to solve the problem.
Posted on Feb 23, 2009
I dropped my Maxtor 3200 Hard Drive. now it makes a soft humm instead of its ususal whir. I checked in my device manager and it gives me a code 10. The Maxtor website says to buy a...
a hard drive is a plate between to feelers. if a feeler is bend it will sound strange. but the problem is unless you know someone who has fixed one of these dont open yourself as you will lose everything on you harddrive if you make a mistake.
Dec 09, 2009 | Maxtor BASICS Personal Storage 3200...
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 200 gig not recognized
Feb 23, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 usb hard drive with windows vista home premium
Hey guys I had the same problem... All the drivers for the device are inside the harddrive. Maxtor doesn't have any because you don't need any. What they've neglected to let any of us know is the power supply provided with the unit isn't powerful enough to run it. Replace the original power supply with another one and this will solve the problem. I replaced mine with an old laptops power supply, the fit was alittle tight but believe me it works.
Jan 29, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Reformatting external Hard Drive
click on the hard drive and use the disc manager to format
or right click on the hard drive properties and use the format tab
May 11, 2017 | Maxtor BASICS Personal Storage 3200...
Maxtor 3200 200GB
The HDD has either failed or requires initializing.
May 30, 2017 | Maxtor Personal Storage 3200 (U01E200) 200...
External harddrive problems
The 3200 will work just fine on ME. The problem is that the drive comes from the factory formatted NTFS which Win9x can't recognize. You'll need to use an XP machine with a 3rd party utility (I use SwissKnife) installed to repartition and reformat the drive as FAT32. (the native XP utility will not allow a partition larger than 32GB) . Incidentally, the 3200 will also work on Win98, Google for 3200_usb_driver.exe and install it before connecting the reformatted 3200.
Sep 08, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor storage 3200
right click my computer
select manage
select disk managment
right click on the maxtor drive then select change drive leter to "L" if you like.
Apr 27, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Not detected by My Computer
Go into Control Panel go into 'Administrative Tools', double click 'Computer Management' click on 'Disk Management'. Do you see the hard drive?? Right click on the drive and select 'Format'. If this didn't help, write back and we'll find another way.
Jul 14, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
161 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
