Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
Pioneer GEX-XMP3 stuck in the power up mode
Removed battery to reset did not fix problem what should i do
  • 3 more comments
  • rdotson3 Feb 28, 2009
    I have the same problem. It keeps cycling through the "powering up" mode.
  • Anonymous Mar 07, 2009
    Same here
  • Anonymous Apr 26, 2009
    same problem - how do I reset?
  • kbc_63 May 18, 2009
    I have the same problem. It's stuck on the powering up screen in & out of the cradle. Have done a battery pull several times with no success.
  • tosienski98 May 25, 2009
    I can not power on the device and when I try to charge it in the docking station it forever says "Please Wait". This unit is useless! Only had it 4 months!!!!
Just off the phone with Pioneer customer service. Apparently a "software glitch" common enough that an internal memo has gone out to replace units under warranty without further trouble shooting. The last step in the process was to remove the battery, place in the original charging cradle without the battery, and hold the power switch down for 10-15 seconds; if the "Please wait" message continues, the unit is defective.
Posted on May 28, 2009
XMp3i is stuck on "powering
Bad TSOP flash chip. No way to fix without disassembling, removing the flash chip, and placing a new flash chip on it. Doing so requires a donor radio (with another issue), and will change your XM Radio ID. You'll also need to have a hot air (or IR) rework station for desoldering the old chip, and a soldering iron for placing the new chip on the radio.
I'd say give pioneer a call since it's a design flaw, and a VERY common issue. My best guess is that it's caused by excessive heat & defective chips.
Aug 07, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
When i turn it on it displays "please wait" but nothing else happens. I have had the GEX-XMP3 player for about a year and half. Is it toast? I've switched out different craddles, but I...
Try pulling the battery for 15 minutes, this should give you a "soft reset". Then try to use the XMP3 in portable mode, so you take the dock out of the station. See if this helps you to boot up, then see if you can go through options/settings and run a factory reset.
Jun 14, 2011 | Pioneer GEXXMP3 Satellite Radio Receiver...
Pioneer GEX-INNO2BK XM Radio Receivers backight problem
Have you tried changing the backlight controls in the menu? Pull up your menu, go to settings, then preference, and change display. Choose backlight display. You can put it always off, always on, or on for however many seconds.
Jun 05, 2010 | Pioneer GEX-INNO1 XM Radio Receiver with...
Portable gex-mp3 gets stuck on powering up
The battery is definately the problem. I have seen many times in this device in particular - the battery shorts to ground - and causes the unit to malfunction.
VERY COMMON and recurring problem in the GEX-MP3
CLICK HERE to read more.
Replacing the battery is as easy as finding an Authorized Pioneer Repair center near you.
Pioneer does not sell parts to unauthorized repair techs.
CLICK HERE to find the nearest one to you. (top right of page)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 08, 2010 | Pioneer GEX-INNO1 XM Radio Receiver with...
I have a pioneer GEX-XMP3 radio. No Sound
The same thing happened to my XMP3, I had to send it to Pioneer for a replacement XMP3........call Pioneer @ (800) 421-1404, Monday through Friday, between the hours of 7:00 a.m.
and 4:30 p.m. Pacific time.
Feb 15, 2010 | Pioneer Audio Players & Recorders
I have a pioneer gex-xmp3 will not power up.
having the very same problem and my unit is only a couple months old . has been nothing but problems but at least it would turn on then , nothing now. I removed it from base and attempted to trn it on ..... nothing but PLEASE WAIT . I:M SO SO SO mad
Sep 04, 2009 | Ministry Of Sound Audio Players &...
Volume control
Remove the back battery cover only. Turn unit on. Insert a tiny paperclip thru the tiny 'reset' hole on the back of the unit inside the battery compartment. OK?
Aug 05, 2009 | Pioneer XM2go Inno Satellite Radio...
I connected my Pioneer GEX-XMP3 player through the auxillary terminals on my Bose Wave radio and the sound is very low. I connected it as stated in the satelite radio book. Help!!
Hi have you set the vlume of the MP3 player to its maximum? You need to do so since the AUX input behind the unit does accept fix line input as standard.
Glad to be of service...
Mar 29, 2009 | Bose Wave Radio
Pioneer Inno Gex-INNO2BK stuck in re-boot cycle
I fixed the reboot cycleing problem by plugging the travel charger into the jack that also fits the home and car cradle. I had the Inno set to auto start when it was powered on in the car cradle. The travel plug must have over-ridden the auto-start setting and allowed it to finish the complete bootup. I then reset the Inno default settings and every thing was back to normal. I do not know what was the original cause of the rebooting cycle problem
Jul 28, 2008 | Pioneer inno2 Portable XM Satellite Radio...
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
5,644 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
