Question about Canon DR-9080C Path-Through Scanner
I have a canon DR-9080c that gives me a PAFCV2.DLL load error
I have a canon DR-9080c that gives me a message PAFCV2.DLL load error when I attempt to save a scanned image to PDF format using
CapturePerfect v. 2.311. Of note, Perhaps the PACFV2.DLL is missing? Does anyone know what is the purpose of PACFV2.DLL? Is it specifically related to PDF files? Has anyone else solved this problem? I noticed one other person had posted a similar problem several years ago but I could find no posted solution.
  • steelwind Apr 03, 2009
    mohanchennai, I also get this error with a dr-5020 using 2.311 but only when I select OCR for the pdf option. Are you running OCR?
  • Anonymous Apr 10, 2009
    I have the same issue. It is only pertinent to PDF scanning. All other formats are fine. I will try to re-install to get the DLL re-written, maybe that will help.
I have resolved this in the past and a new user just brought it up again.
The pafcv2.dll in Captureperfect 2 does not seem to work. If you install CapturePerfect 3 and copy the pafcv2.dll into captureperfect (c:\program files\canon electronics\captureperfect2 or whatever install path you used), you will find that you can now scan into PDF, even in batches!
Posted on Jul 08, 2009
    Problem Solver:
  • 7 Answers
This is caused by Canon USA sloppy testing and packaging of the software. For those of you downloaded from the Canon USA site, you get errors because those files were missing at the source. If you download from the European site : http://software.canon-europe.com/products/0000665.asp, you will get a working verion. If there is a repository, I would upload those working files to it. Now, the SCSI Canon 2080C and Capture Perfect 2.312 are working perfectly on my newly installed Windows 7.
Just a few notes for people seeing different types of errors. 1. After you've updated Capture Perfect and you no longer see the scanner, you should check in your windows\twain_32\Canon Electronics\ directory if the DR2080C.DS file is newer than 12/2004. If not, you need to run the 2080DRIT software and reboot. 2. If have a adaptec SCSI card and thinking about migrating to Windows 7, be afraid not. Adaptec has the drivers on their site. Don't just search google, you will get a lot of junks. Go to adaptec.com directly then search for your card series. 3. Check out "SU2000" software from the EU site. It appears to be a "lite" version of Picture Perfect. It does not support tiff and some small features. But it pretty much does all the important functions.
Posted on Dec 14, 2010
I just fixed this problem on my computer. i had acrobat reader 9.1 and i replaced it with an old version 5. i also reinstalled capture perfect 1.0, but my guess is that i could have stayed with 3.02 or whatever. it's the same issue as office 2000 can't open files created in the office 2007 version
Posted on Oct 28, 2009
  • 4 Answers
I just had the same problem and solved it using the solution posted by skidoggeruk. I can email the correct and working version of the file to you if you are unable to extract it from the version 3.0 download. email request to daveydamit@hotmail.com and I will reply with working version (it's very small). Then just copy the file into your install path for CapturePerfect 2 (most likely C:\Program Files\Canon Electronics\CapturePerfect 2.0)
Posted on Aug 28, 2009
  • 490 Answers
I have two Canon DR scanners and the problem reported by you did appear in one while trying to get PDF output. The other worked smooth!. I found that the one running Captureperfect 2.1 version created PDF whereas the one with 2.311 reported the same problem. I tried couple of options, but did not work. may be you can try and locate 2.1 version and try. If you give me yr mail Id, I can send 2.1 version (smohan54@yahoo.com)
S. Mohan, Chennai, India
Posted on Feb 24, 2009
  • 1 more comment
  • ADHD_Dad Dec 14, 2010
    Check to see if your program director has the paftopdf.dll file. Missing this file will cause pafcv2.dll error. If you do not have this file, you probably install the 2.311 version directly without an earlier version installed?
    I finally realize why some of the people are getting "pafcv2.dll not loaded" error. This is caused by Canon USA sloppy testing and packaging of the software. For those of you downloaded from the Canon USA site, you get errors because those files were missing at the source. If you download from the European site :http://software.canon-europe.com/product... you will get a working verion. If there is a repository, I would upload those working files to it. Now, the SCSI Canon 2080C and Capture Perfect 2.312 are working perfectly on my newly installed Windows 7.
  • 24 Answers
Download , extract and put pafcv2.dll file into program folder -->
should work.
http://www.rencomusa.com/FIXYA/pafcv2.dll.zip
Posted on Oct 08, 2009
    You also need pavtopdf.dll
  • debaser216 Aug 02, 2011
    Where can I get pavtopdf.dll ?
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
Canon DR3080C pafcv2.dll load error
Check that the feed switch actuator is not trapped below the feed bed.
Blow out the interior of the scanner with canned air.
Dec 03, 2009 | Canon DR-9080C Path-Through Scanner
Won't scan to PDF with Capture Perfect 2.0; Error
There are two versions 2.0 and 2.3. One of them converts to PDF without PAFCV2.dll load error. Try and down load from http://software.canon-europe.com/software/0022439.asp?model= Incase this doesnot work, you need the other version.
I generally dont do direct conversion to PDF. I clean the images, create multipage and then convert to PDF and hence don't know which version works. I have both versions. Incase the downloaded version does not work, pls send a mail to smohan54@yahoo.com I shall send you a copy.
Oct 08, 2009 | Canon DR-2580C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C paper tray lift broken
Michael, U can buy 9080C service manual at tradebit.com 9080C has no belt for lifting the tray. It has arm and a few gears. Ensure that the plastic gears are not deformed. Good Luck. Which version of Capture perfect do you use?
S. Mohan
Jan 30, 2009 | Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
4,167 people viewed this question
old marine
old marine
