Question about Clarion DPX1001.2 Car Audio Amplifier
Clarion Dpx1001.2 no audio output
I have a Clarion DPX 1001.2 amp I got and it did'nt come on when I put power to it. Then I took it apart and started doing some testing and found 1 bad zener diode. Well I replaced the diode and now it comes on but no audio. I checked all tansistors and all check out. Maybe I should do some more testing but check the smaller components more than I did. But, it has this black square thing that resembles a processor, It's got Tripath wrtten on it TA0102A. I'm thinking this might be the problem. Any help greatly appriciated. I have 2 degrees in electronics so I know what I'm doing. Please help
  • Mark Skinner Feb 24, 2009
    Hello, I also have built circuit boards and have made my own amps, car and guitar amps. About 15 years ago I made them. I also have 2 degrees in electronics. Also got those 16 years ago. I was just asking on here first cause I just got back into repairing electronics, I should say mainly car amps and currently opening my own business. It's all coming back slowly. second I just wanted to see if anyone else had this problem for a quick fix and it's a class T and has that Tripath modual and I have'nt had the knowledge nor came across any of these yet from my customers. So anyway, no my friend it's not the Tripath. After I replaced the zener diode and amp came on I was thinking the same thing. So the next day, cause it was late, I was doing some more checking and found resistor R46 which is a 1.1 ohm resistor was bad. Replaced and amp works great. Resistor comes off the torroidal transformer then into a diode. So make sure you allways check your components, all of them if you have to. Also a guy on here named pbabin on here helped me with this. He is a very nice and well knowledged person and we are becoming goos friends. He gave me the to check the resistor also. He has his own sit dedicated to car amp repair. I recomend to check it out, it's a great site that help people repair amps. It's www.bcae1.com Thanks for the help though I appriciate it.
I got the same problem where can I get the tripath at
Posted on Jun 16, 2011
  • 24 Answers
Hi i didnt wont anyone to get confused i just wanted to clear up that all the dpx amps are class g/h wich is basicly class h/d or high speed class d. most companise call it ice tech. by the way good troble shouting on the resistor thats wat got mine. its not a bing and howell desin its a very strat forward bord to work on i have a dpx 1001.2 thay are rated at 500x2@1 ohm 1000x1@2 rms power. mine is suped up i have 2 9600uf 50v caps on the out put and a 1.000.000uf or 1 ferid cap one the power supply mine is a little over kille it dose 872x2@.6 ohm and 1734x1@1,1 ohm with 3 40 amp fuses at 13.8
Posted on Jul 08, 2010
    Problem Solver:
  • 11 Answers
I BUILD CIRCUIT BOARDS FOR A LIVING AND SOUNDS TO ME THE TRIPATH MAY BE FRIED. I WOULD TRY TO REPLACE IT.
Posted on Feb 24, 2009
2012 jeep dead
Replace your battery. It's dead I feel. You can try to fully charge it up but if you had to replace the fluid in the battery it does not sound good. Make sure your battery cables are tight and clean on both ends.
May 29, 2015 | Jeep 2012 - Liberty
Try change my car radio cd .after connecting electric power and audio cable the new radio panasonic start 1 minute and stop loss power i reconnecting the old car radio ask me for cood the car is
You need to enter the radio code.....this should be with the service book or handbook, or contact the main dealer who will have a record of the code!
Jan 26, 2015 | Car Audio & Video
How do I reset a Kenwood KDC-24BU that is flashing "PROTECT"?
Replace the blown/shorted amplifier output Mosfets that are causing it, and it will then be happy to reset itself :)
Jun 01, 2014 | Car Audio & Video
How do i program a clarion db158r car streo
Go here to download operator guide.http://www.clarion.com/gb/en/support/owners_manuals/select/D_H/index.html
May 26, 2014 | Car Audio & Video
Fm works, am does not
Check the antenna connection. A poor connection will often be good enough for FM but make AM reception so bad the the radios auto-gain circuits will mute the output unlike old AMs that would just produce loud static in poor signal conditions.
Apr 17, 2014 | Car Audio & Video
No power to amp
check and try finding another grounding spot
May 16, 2010 | Lightning Audio B4.250.2 Car Amp
Lightning audio b150.2 as soon as +12 is hooked up blows 25 amp fuse and the c2 1000uf/35v capacitors blow???????
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you.
Aug 25, 2009 | Lightning Audio PC2 Capacitor Car Audio...
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
Clarion DPX1001.2 Car Audio Amplifier Logo
592 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
