Question about Toshiba 42H81 42" Rear Projection Television
My color is washed out and dim and the colors are wrong . Toshiba 65h83 projection hd tv
    Problem Solver:
  • 15 Answers
My dfaughter has the same problem. I looked up her TV manual on the internet.
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/46h83_51h83_57h83_65h83_rev2-26_ownman.pdf
You can download it on the above link if you don't have your manual. On page 25 of the manual it says to press TOUCHFOUCUS button on the TV once. The TV will enter auto-convergence mode and adjust convergence automaticly. That button is lacated to the right of the TV power button (you may have to flip open the cover door on the right of that power button). It will be the last button on the right.The TV has to have been on for at lest 30 minutes. When you press that button a screen will pop up with the words TOUCH FOUCUS. When finished the screen will have TOUCH FOCUS FINISHED. If an error come out press that button again.
This color convergence meens it will adjust the three red, green and blue colored light bulbs to converge together on the screen at exact precision to produce exact color. I have to admit I have not gone to my daughter's housr yet to do this. Good Luck to the both of us.
Posted on Feb 24, 2010
    Genius:
  • Toshiba Master
  • 1,646 Answers
I don't know your model, therefore I will tell you genericaly what the problem may be.
There are many things that can cause this type of fault. The response of the video amplifier stages would have to be checked right up through to the output that drives the projection. it is also possible that there is a fault with the colour demodulator. If the set uses projection tubes it is possible that the tubes are weak, or there is dirt in the optics. Colour demodulation problems can also cause the colours to not be correct. Many models using tubes have an optical transparent cooling fluid in front of the tubes. This fluid may have to be changed.
Posted on Feb 23, 2009
Colors washed out
Hello, is the color dim or are the colors misaligned? If their misaligned the convergence i.c.'s have gone bad. tks
Nov 05, 2013 | Toshiba 57H94 57" Rear Projection HDTV
My Toshiba theaterwide hd has no color. It just stopped working
You need to replace the color wheel.
Unfortunately they do not sell that part you need to buy the complete Light Engine or a new TV.
Jul 30, 2013 | Toshiba TheaterWide 52HM84 52" Rear...
I have a toshiba 56hm195, colors skin tones are washed out, reds
I'm having the same problem; have you found any solutions yet?
Dec 22, 2009 | Toshiba 56HM195 56" Projection HDTV
I have a Toshiab 57H82 HDTV and when I connect my playstation 3 to the colorstream HD 2 input the colors are primarily green. In colorstream HD 1 the ccolors are fine, but its becoming a hassle having to...
If you have the wires switched GEEN,BLUE,RED on one end the color will be wrong. Check that the color off the wires are matched. Try a new cable. I've seen this a lot.
Nov 28, 2009 | Toshiba 57H82 57" Rear Projection...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
Bottom left corner of my toshiba 65h83 is blurred with color distortion mainly magenta and green. Distortion Is a half moon shape with the open end facing the edge of the set. Total distortion takes up...
Have you tried the "Magic Focus" Button/Option in the Menu Setup Screen? If you have and it still is there, You Have a Burned out Color Tube. It is Cheaper to Throw it away and Buy a New one.
Good Luck..
May 12, 2009 | Toshiba 42H81 42" Rear Projection...
Blurry Philips TV model # 51PW936317F
The coolant will become congealed in Phillipd rear projections and the color will get very dim and hard to focus. You can get the coolant replace kit at the following link which contains the coolant for all 3 tubes and step by step instructions om CD. Heres a link to the kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 25, 2009 | Televison & Video
Toshiba 42H81 42" Rear Projection Television Logo
215 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
