SOURCE: my snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
SOURCE: snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
SOURCE: SNOW BLOWER FRICTION WHEEL WON'T DISENGAGE
Use a good quality silicon lube and spray into the top of the cable. Do this until it comes out the bottom, a little at a time. Also, spray all pivot points. Don't use WD-40, it will freeze. Lube everything at the end of winter and again before winter.
SOURCE: Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
