Question about Nikon D40x Digital Camera
Same thing here on my D40. Was on a camerastand (tripod) and fell (toppled over). Everything seems normal apart from the error mentioned above. Can't take pics neither (black), and shutter error....
  • 423 Answers
I can help you understand what is going on with your problem, but it is a problem you should not try and fix yourself. When your camera hit the dirt, it probably broke the shutter mechanism.
The symptom you mentioned with the black pictures means that the shutter (allows light to the medium) is not moving.
When you take a picture, the shutter moves very fast. It is what regulates how long light hits the medium (regular cameras, it's film, in digital cameras, it's the ccd.)
Bottom line, your going to have to take it to an authorized repair shop for the make of your camera. Probably be around $200. to repair. Sorry for the bad news. Let me know what you think in a comment if you want, and thanks for coming to FixYa. Feel free to rate my answer.
Rob
Posted on Feb 23, 2009
3rd shaft lost inside 2nd shaft
Yup.Close all leggs up,tape the other 2 so they don't come out,then shake the tripod like your shaking a thermometer to get the mercury down.That lost leg should slide out easily.Once out,place a small hose clamp on each of the final legs just above the rubber tip and this will NEVER happen again.
Apr 15, 2014 | Promaster FW26T Featherweight Tripod
Forgot the 3 number combination lock for my samsonite vanity case
Turn your suitcase (Samsonite F'LITE comfort) upside down. At this position all your numbers look upside down. Now with the help of a torch light you should see a small gap above the rotating thing (the one with which you change your number) Take the first rotating thing and rotate from 0 to 9, at some particular number you can see a small hole inside the small gap which I have mentioned before. Do the same for the next 2 rotating thing.
When you are done you can see the small hole(a tiny spring like material is seen in the hole) in all the three small gaps.
Now you can open the number lock. :-)
Aug 24, 2013 | Samsonite Tripod
I have a TARGUS TG-5060TR tripod. The plate that connects to the camera broke when it fell over. Any chance I can purchase a replacement plate.
My mounting plate broke as well when it fell over. There is a vendor on Amazon who sells them, but they are 7.99, and shipping is 7.00, not Prime eligible, so just the plate comes out to 14.99, which is about the price for a new TG-5060. I'm going to ditch the mount and drill a hole through the tripod quick release, then use a piece of bolt with the head cut off and a wing nut to attach it. It's either that or through the tripod away, and I hate to waste things that can be fixed.
Jul 07, 2010 | Targus TG50TR Tripod
Cannot remember my code to unlock my samsonite breifcase
Turn your suitcase upside down. At this position all your numbers look upside down. Now with the help of a torch light you should see a small gap above the rotating thing (the one with which you change your number) Take the first rotating thing and rotate from 0 to 9, at some particular number you can see a small hole inside the small gap which I have mentioned before. Do the same for the next 2 rotating thing.
Jul 09, 2009 | Samsonite Tripod
Pin fell back inside the central shaft.
Use a good strong magnet from the outside while holding it upside down. Move the magnet around the shaft as if going through a maze that you can't see- untill it finds the exit path out! Take an old hard drive apart and use the magnets they have-they're very powerful.
Oct 08, 2008 | Gitzo Mountaineer Mk2 G1228G Tripod
My d40 won`t take pictures
Try Blow cleaning the Memory card slot ... sometimes dust does that
Oct 05, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
322RC2
I just had this same problem and came across your post.  In frustration I held the grip and then let it go very quickly where the grip 'snapped' back.
Now it works.  Go figure.  I will mention a very small piece of plastic fell out of it, but it does not appear to hinder the functionality.
Jul 01, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
DROPPED NIKON d40, now my pictures are all dark
First u have to reset the camera,go through the menu and select reset and yes. the camera will take default settings.Try now.
Reset the camera opening the connector cover.
You try with a different compatible lens .If works we have to change the lens.
Remove the battery and get fully charged .Operate all switches for some clicks. then put the battery and try.
Then u have to consult a mechanic.
Apr 27, 2008 | Nikon D40x Digital Camera
Faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
Nov 01, 2007 | Nikon D40x Digital Camera
My screen keeps showing card cover open error.
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Nov 17, 2006 | Olympus FE-130 Digital Camera
Nikon D40x Digital Camera Logo
55 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
