Question about Kenmore Washing Machines
Washer sparks at outlet then gets no power
There is no power to the washer. When I unplug then plug it back in, there is a small spark at the outlet, a flash of the control lights and a beep, then again no power. This happened out of the blue, there was no event that seemed to cause it. Does anyone have a clue how I can fix this? The washer is 2.5 years old and has been operating perfectly since I got it. It is not on an extended warranty.
  • 2 more comments
  • David Del Real Feb 23, 2009
    Yes, it is an Oasis 110.2707 top loading washer. Thank you!
    Thanks for the try but that wasn't the problem. I removed both pumps and check them both. No blockage!
    I think the problem is the user interface or the mother board. When I unpluged the user interface the machine seemed to start but then stopped but did not lose power. When I repugged in the user interface and pugged in the power the machine lost power again. This makes me think it is the user interface, what do you think ? Is there any way to test both the user interface and the mother board?
  • David Del Real Feb 24, 2009
    Yes the impeller seems to spin freely. The machine was not in use when it began to fail. It had no water in it. We were just using it for the first time after a few days of non-use. I'm going to try replacing the user interface board unless you have a test for the user interface board and the mother board.
  • Ron Coons
    Ron Coons May 11, 2010
    ???? is this perhaps an OASIS, mashine?? toploading no center agitator????
    President:
  • Kenmore Master
  • 2,651 Answers
Heres what i think is the issue. sounds as if you have something lodged in hte pump assembly. to correct this unplug the unit, and while standing in front of unit leant in over to the left side. scoop out as much wateras possible.the bottom ofthe unit is open and youll findthe drain pump in the back bottom of right side of tub.after removing as much water as possible, remove the pump hose from the tub and the pump will release with (3) 5/16" screws. almost sure that you will find something in that pump!!!
Posted on Feb 23, 2009
  • Ron Coons
    Ron Coons Feb 23, 2009
    were you sure to look inside the pump impeller and make sure it spins freely???? debris will lock the impeller from spinning although there was nothin in the hose.
  • Ron Coons
    Ron Coons Feb 24, 2009
    if your able to "pop" hte main top assy, 2 clips perhaps 2-3 inches form each side between the top and front panle. there is a techsheet/trouble shooter taped to the inside of thefront panel
Why does laundry center have no power?
Kenmore washer 40272 has no power. Unplug and wait a ...
www.shopyourway.com > Manage My Life > Questions
I have a Kenmore 40272 front load washer. ... I remove plug from outlet, wait, then plug back in. ... Do you have the washer plugged in to an outlet or is an extension cord being used?
Nov 06, 2015 | Kenmore Washing Machines
My power button comes on sometimes and washer works fine. Then sometimes it wont come on. The plug sparks when you plug in if unpluged
IF U HAD SPEAKING ITS ARCHING AND THATS DANGEROUS U NEED TO FIND THE SHORT LOOK AT UR TERMINAL VERY CLOSELY AND LOOK FOR CORRODED OR BROKEN BURNED OUT WIRING, YOU MAY HAVE BLOWN A FUSE SOMEWHERE IN WASHER OR EVEN AT THE BREAKER BOX
Oct 17, 2014 | Whirlpool duet Washing Machines
When I plug MY washer into the outlet it sparks and it read ub and keep flashing on the panel
Check your outlet by plugging something that works properly into the outlet. If it works right, then the problem is a short in your washer. If it still sparks when you plug something in, there is a problem with the outlet itself. Get a qualified person to check out and /or the outlet.
Sep 26, 2014 | Washing Machines
LG washer #WM2655HVA won't start again after a cycle, unless unplugged, hand-turn drum, makes a beep, static spark as plugged back in, then a new cycle begins. Why?
Have you checked the wall power outlet for proper ground and
polarity? Try using another outlet near by using a "heavy duty"
3 prong extension cord. If problem persist chances are the Main
PCB is bad.
Aug 15, 2014 | LG SteamWasher Series WM2655HVA Laundry :...
Washer icons won't show up and washer sparks at plug when I plug it in.
If the plug is fused then the fuse should blow before an appliance catches fire. If you go here they have a great customer service base and can recommend an authorised agent to look at and repair your machine if needed. If you want a manual they can also supply you with one just to make you more confident about the operation of your machine.http://www.fisherpaykel.com/us/laundry/?productUid=49343ABD-C773-932B-26D02C8672FC7E2B
Mar 11, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Washer is not grounded properly
have the outlet checked by an electrician or qualified person to be sure the ground wire on your outlet is properly connected or that you have a good working outlet
Feb 08, 2014 | LG WM-2277HW Front Load Washer
Washing machine will not turn on. yes i checked the outlet
Make sure that the outlet is working even though the breaker is okay. Plug a small lamp or appliance into the washer outlet to verify that it is working.
If the outlet apparently has power the plug the washer back in and listen carefully for a click from the CCU (Central Control Unit or main control board shown in the first image below). If you do not hear a click then I recommend that you unplug the washer and remove the top panel (shown in the first image below). Check the wiring harness connections on the control board. I provided a wiring diagram in the second image that shows the path of power to the CCU. If you have a volt/ohm meter and the technical expertise, you can check the continuity of the power supply to the control board (wires traced in red and green on wiring diagram below). If the CCU is apparently getting power but does not click shortly after it is plugged in then it will need to be replaced.
You could also have a failed user interface touchpad assembly that would prevent the washer from powering up.
These tips may help you determine the cause of this washer failure.
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Pf error
Pf is power failure code you must push clear or reset washer by unplugging and plugging back in Good luck
Mar 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore oasis he 580 washer will not power up, I unplugged,
I have had the same thing happen. I unplugged it for a day and when I replugged it in, no spark and the machine worked again. I figure there is an internal over-voltage that get tripped by a faulty component. I frankly think it is just a bad electronic design, but I am investigating.
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite OASIS 27082 do not power up
The motherboard (controller) has died.
You will have to replace the motherboard.
This motherboard is the cause of the dreaded F1 error codes as well.
Look at some of the other posts here for F1 errors.
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Open Questions:
Kenmore Elite HE4T Washing Machine Diagnostic Test Didn't complete and clothes aren't spun as dry as in the past I have a Kenmore Elite HE4T washing machine and I noticed that recently it isn't getting all of the clothes completely dry from the final spin cycle. Thus, the dryer has to run through two cycles to get the clothes dry. I did a bunch of research and made sure there weren't any kinks or blockages in the drain lines; and opened up the bottom of the washer and cleaned out the drain cleanout. I found a few pennies, but everything seemed to be working ok. I ran a load and had the bottom open so that I could make sure the motor, drain and belt were all working properly. The drain does get the water out of the washer, so the clothes aren't sitting in water, they just don't seem to be spun as fast or as long as they used to. I always put it on the "extra high" spin setting no matter which type of load I run. So, I found a way to run the diagnostic test on the washer and it went through C0-C5 (the agitation step) and all worked great, until it wouldn't come out of C5 after at least 10 minutes and go thru C6-C8. I had to cancel the diagnostic test and hit the "drain and spin" button to get all of the water back out of the washer. BTW, the "drain and spin" seems to get the clothes a bit drier than when I have it run through the "normal" cycle with the "extra high" spin. If anyone has any other thoughts, I would really appreciate it. This unit is in a small space with the dryer attached so to take it out and do repairs is a pretty big hassle. It has had a new control board and two new fill valves in the 10+ years that I have owned it. Questions I have: 1.should I remove the entire drain pump to make sure there isn't anything lodged in it? 2. could it be the belt slipping slightly and keeping the spin from reaching its 1200 RPMs? 3. Anything else I may be missing???
Jan 17, 2017 | Kenmore Washing Machines
Washing Machines Logo
252 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
