Question about Epson RX620 All-In-One InkJet Photo Printer
The light cyan printer head is clogged
The light cyan printer head on my Rx 620 Emerson printer is clogged. I have ran the printer's head cleaning process, probably 6 times, and it helped for a few copies but then clogged up again. I have read where other printers can be cleaned with a special cleaner. Ths is a process where the printer heads are cleaned. Is this an option for the Epson 620? If not, any thing else I can do?
  • Anonymous Mar 14, 2009
    We are having the same issues, but with our black ink.
    Same problem - yellow ink. So frustrated.  Can't remember how many Epsons I've bought/owned over the years but god strike me dead if I'm ever led into buying another one.  (Always thought that each brand had it's own issues and that the devil-you-know is better than the devil-you-don't. I'm ready for a new devil.
    Problem Solver:
  • 11 Answers
This article might help
http://www.ccs-digital.com/cartridgeproblem.asp
Posted on Jul 07, 2009
How to fix blue nozzle
Beings there are to "cyan" color heads, light cyan and regular cyan, your question makes little sense. Either way it sounds like both print channels are clogged so you are getting no clue output at all. FIrst check your cleaning pads and the parking pads. They are worn out or dried out by now most likely. One way to help the cleaning Process is to actually push the printhead into the pads when it is running a cleaning cycle. The idea is you want to get a pressurized line so its pulling maximum ink thru the lines. This often clears up many light clogs.
Jun 20, 2014 | Epson Stylus Pro 10000 InkJet Printer
Hello there, my trusty Epson Stylus Pro 4000 isn't producing as wide a range of Cyan as it used to. Swatches of cyan going from 10 to 100 were fine and now when the swatch hits 70 it's pretty...
Sounds like the cyan is somewhat clogged. Honest advice would be to replace the printer. Inkjet printers are 95% of the time not worth servicing and it is typically economical to just replace.
If your looking for a printer with long term investment spend the extra money for a laser printer. Much easier to repair.
There is a reason that Inkjet's has no repair section in the A+ certification.
Comment back if you need anything else.
Thanks!
Sep 08, 2011 | Epson Stylus Pro 4000 InkJet Printer
Hello my mp520 will not print cyan i think the head is clogged
go through the printer cleaning process a few times. with just the cyan cartridge installed if this does not work it would be better to buy an new cyan cartridge.
i hope this was useful.
Dec 12, 2010 | Office Equipment & Supplies
Suspected clogged blue ink tube
most of the time, the print head need to be replaced for your case... but there are cases whereby it's the ink cart that causes the ink clogged.. you can try replacing the cyan ink and do another round of cleaning.. but chances are slim...
May 24, 2010 | Brother DCP-120C All-In-One InkJet Printer
Cyan ink doesn't print most of the time, even after multiple cleanings
1. this is a clogged printer head
2. the only way to remedy this is to replace the printer head.
3. Here is a site that I ran across that give a general cleaning guide to clogged heads.
http://www.crazysquirrel.com/diy/printer-head-cleaning.jspx
Apr 19, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cyan ink wont come out
It is probably clogged. You need to using lint free swabs and vinigar to clean it. The vinigar disolves deposits of dried ink.
If this doesn't work then it can be a print head problem and that is usally cheaper to replace the printer than it is to repair it.
Oct 24, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP510 skips and makes 2 small blank lines going DOWN the pages, in only cyan and magenta. The two lines show up on the Nozzle Check Pattern but only on cyan and magenta.
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magicis ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Sep 11, 2009 | Office Equipment & Supplies
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Phaser8560 mfp cyan jets clogged
Not really, The print head has most likely failed and in need of replacement.
That machine comes with a 1 year on site warranty. If its less than a year old, call Xerox, they will repair it on site.
Oct 02, 2008 | Xerox Phaser 8560MFP Laser Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
552 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
