Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
Blank monitor Monitor has power, but only shows Dell logo briefly before going blank.
  • adgrisham Mar 29, 2009
    Did you get your issue fixed? I have the same problem.
    Scholar:
  • 135 Answers
Try the following link for all Dell monitor problems:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&docid=FC55E86F0611BEE3E030030ABD620A8C&l=en&s=gen
Good luck and hope this helps.
Posted on Feb 23, 2009
Dell logo won't go away.
If you are lucky a hard power reset will fix this. Disconnect all the cables, hold the power button on for 10 seconds, release the power button, reconnect the cables and turn it back on. Otherwise you may have a hardware problem.
Jul 09, 2017 | Dell E2210 22" Widescreen Flat Panel...
1905FP Monitor Powers up, briefly shows logo, blacks out.
Look inside for bad caps with bulgng tops, worst case will be shorted out transistors in the backlight inverter circuits or bad lamps. Check to see if you do have he 12vdc for the inveter circuits. See example of failed monitors with bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 12, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
My new Dell flat screen monitor is blank and posting a message - entering power save mode- ... when I restart it briefly displays the Dell logo and other normal display at normal startup then switches to...
You'll need to troubleshoot a little. SOmething may be broken, but you'll need to find out what. 1: Try the monitor on another computer, see wether it will work on that one. If it doesn't, the monitor's broken and you're probably going to need a new one. 2: If the monitor does work, put it back, but now use another cable to connect it to the PC. If that fixes it, your cable was broken. 3: If not, you could try to switch the graphics card in the PC with another one. Do not attempt that, however, unless you know what you're doing. If you don't, get someone you know to do it for you, or take it to a computer shop. If the PC will boot with another graphics card, the old one is broken. 4: If not, it may be your motherboard that's broken. Repeat step 3 with it. These steps should fix your problem. If not, please post back here. Regards, Yannick.
Jun 07, 2009 | Dell E193FP 19" Flat Panel LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Monitor Screen goes black seconds after turn on-
I ended up fixing my problem, but I'm not sure what the solution is. I had some faulty electrical equipment that I was using to power the monitor (220V to 110V converter and a bad power strip) and I got rid of them. I was using the converter because I moved to Israel and I thought I needed to feed the monitor only 110V, but I now realize that the power cord for the monitor has a built-in converter that accepts 220V input. Now the monitor is plugged directly into the wall and is working fine. Try using a different power source (maybe the wiring or plug you're using is faulty). Good Luck!
Apr 21, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
My E172fp has a blank screen...when i unplug and plug it back in,the "dell dimension" or whatever that logo is comes on for a second, then the screen goes blank and stays that way.another monitor works...
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Feb 25, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
304 people viewed this question
Alun Cox
