Peavey floor monitor speakers
I have 2 peavey floor monitor speakers Model-112HS BW. My issue is the volume control: It is either a short or the potentiometer is bad. You have to turn the volume control numerous times, and/or tap the knob to make a connection to get the audio to come thru. I have opened the speaker volume control from the speaker and even sprayed electronic contact cleaner on as well. My question is? Is there replacement parts that I can order to correct this. Or can I just bypass the volume control all together and just control it directly out of the amplifiers master volume?
    Scholar:
  • 156 Answers
You can bypass the volume controller and use the master control. just take out the volume controller and splice the wires from there straight to master control.
Posted on Feb 23, 2009
Wish to bridge onto mixer output to send to separate amp for use in another part of bldg. without interfearing with regular speakers. Peavey XR684
simple !! most peavey mixers have a monitor output !! you can use that to feed new amp , and theres your volume too !!! or if your already using the monitor output , you can buy a split cable (1 in 2 outs) for main send !! this cable would have to be kept short or it will induce HUMMM !! and in real extreme cases if your using a low Z send (cant think as to why ) a device known as a (direct box) normally used by instrument sends can be used in reverse to "tap" into a low Z send and output with a unbalanced send for an amp to your other room , but hey why not just add a speaker with a volume control to it for this smaller room ? and forgo the new amp
Oct 05, 2016 | Peavey Music
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
How do i hook up monitors to peavey 8300 mixer
Make sure main monitor switch is pressed in, look at back of unit, the speaker jack labeled main/monitor is now monitor output, you may use 2 8 ohm speakers, use controls on front labeled monitors.
Jun 27, 2012 | Peavey XR 8300 8 Channel Powered Mixer
Looking for replacement components for my peavey speakers 2 x 15 inch 2 x tweeters 2 x crossovers 2 x horns all above for 15 inch peavey eurosys 4 product 15005760 2 x 12 inch 2 x...
Fixya doesn't do prices or delivery. We only supply information. See the link for spares suppliers including Peavey themselves.
Peavey Replacement Repair Parts, Speakers, and Accessories
https://www.simplyspeakers.com/peavey-speaker-repair-parts.html
Factory replacement Peavey speaker parts, diaphragms, replacement baskets. ... Peavey 1208-8 SPS BWX Factory Speaker Basket, 12" Black Widow, 8 Ohm, 00560770. Peavey SP-15825 Factory Speaker Basket, 15" Scorpion, 8 Ohm, 00015040.
Peavey - Replacement Speakers, Raw Drivers ... - Parts Express
https://www.parts-express.com/brand/peavey/339 Results 1 - 16 of 323 - Welcome to the Peavey Store at Parts Express. Peavey was founded in 1965 and is now one of the best known names in professional audio. With innovative products such as their field replacement baskets, powerful amplifiers and PA speakers they have become a mainstay of musicians around the ...
Speaker Components - Peavey.com
https://peavey.com > Support From the Low Rider™ sub woofers, with incredible power handling capacity and impressive bass response to the steadfast Black Widow® and BWX™ speakers with replacement basket assemblies, the Peavey line of speaker components is consistent and innovative. Think it might be difficult to make up your mind what ...
peavey speaker spares Google Search
Dec 23, 2017 | Audio Players & Recorders
My peavey 218 subs are crarking or sound dissorted.How can I check them out
Hello Sir, Hi, distorted sound can be caused by several factors, one would be that the source, overdrives the power amps. You need to lessen the signal, if the source has a volume control set it to half. Another is the power amp itself is defective, The likely culprit it the Integrated power amp. this should be checked by a technician. and lastly the loudspeakers, to test just simply swap the other channel driver unit to the questionable one. check If the sound returns to normal. Several factors also are low voltage supply, leaking capacitors. there are no user serviceable parts here.
Aug 13, 2010 | Peavey 1808-4 SPS BW Car Speaker
Volume control of peavey bass guitars
Sorry but your post did not provide enough info. Are you having a problem with the volume control. Do you need a wiring diagram. What model Peavey bass do you have. For instance, the Peavey bass I have has active electronics ans requires a 9 volt transistor radio battery to power them.
Jun 22, 2010 | Peavey Millennium Bxp 5String Bass Guitar
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Floor monitors Peavey
Can you tell me how every thing was set up,
Head unit/desk
amp/s
speaker configurations
power supply and room area
thanks
Jun 19, 2008 | Peavey CH1 Speaker
Hi, I need to replace the baskets on my peavey impulse 200 speakers. The baskets currently in them are 1268MR BW... (12 inch black widow) I am wondering if I can use differant baskets, due to the fact I'm...
Hi dieselbob25
Whats happening to the 1268? Oh and I couldnt find that model in the standard range available to the public at the peavey sites I checked here and Peavey
They may be a special edition for the Impulse boxes. Can you tell me what is happening to the speakers? Are they burning voice coils or what. May indicate another area of concern that is making them fail.
regards
Graeme
Apr 14, 2008 | Audio Players & Recorders
Peavey PR10PN Powered Loudspeaker
you mean a series connection, I'm assuming that you are connecting two speakers to one channnel (the right or left ) of the stereo. you take the positive and the negative leads and you put one on one speaker and the ohter on ther other speaker, positive (+) to positive (+) and negative (-) to negative(-). then you simply connect the 2 leftover connection of the speakers together with a wire. Be carefull though becaus if you do it wrong, it could short out your stereo or it will sound really bad...
Dec 27, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
1,271 people viewed this question
 Grubhead
Grubhead
