Question about LG enV VX9900 Cellular Phone
No sound comes out of my LG ENV cellphone earpiece
The phone speakerphone and bluetooth work, but the earpiece has no sound. A local verizon wireless technician said the phone speaker had water damage and tried to fix it. No luck. Can you help?
  • 2 more comments
  • mary324 Feb 25, 2009
    no sound on keyboard or earpiece/ phone well ring but i cant hear anythiong/texting is fine//happened suddenly/no water damage
  • Anonymous Feb 25, 2009
    Have the same problem with the phone. The sound out of the earpiece is not working, but i can hear the ringer just fine. I can plug in an earpiece, and it works fine, but there is still no sound out of the ear piece. It says that there was water damage on the battery, but i have never had any water damage. I take good care of my phone and I have had it for a little over a year and a half, so I can imagine it is a problem with the phone getting old. The Verizon tech also said that it would be $50 to replace my phone :/
  • bubble862 May 07, 2009
    I had the same problem. I think the manufactures make it that way convenitly when your waranty is up. Then they try to say ts water damage to get you to buy a new phone,
  • jennifer1277 May 11, 2009
    I have had nothing but problems with this phone. I've had the Env (4 of them now) for about a year. Every few months random things go wrong with it. This time I cannot hear anything out of the earpiece. I am very careful with my phone so I don't understand how I keep getting bad ones.
    Any help would be appreciated.
    Problem Solver:
  • 15 Answers
This is a very-well known issue and defect. Documented by Verizon Wireless and by the manufacturer. There is supposedly a workaround, which is a simple as pressing the speaker key right next to the "CLR" key, however I have tried it on several phones to no avail. Recommend warranty replacement.
Posted on Aug 16, 2009
4 Suggested Answers
RZRsucks
  • 91 Answers
SOURCE: earpiece
the speakerphone speaker is actually just kinda resting inside the phone. If you have dropped it recently it might have just become disconnected and you can have a proffessional put it back in place for you. If you really want to attempt this yourself you can email me at drowning445@yahoo.com and I will send you a guide on how to do this. I don't recomend it though
Posted on May 13, 2007
SOURCE: Speakerphone activates for a few seconds when answering calls
speaker phone activates a few seconds when the phone rings... what can I do to solve that?
Posted on Jun 09, 2009
SOURCE: LG enV earpiece and key sound not working
go to tools and setting --> sound settings --> keypad volume...see if you see "KEYPAD VOL-EARJACK"...that means that your phone is stuck in EARJACK mode....get a wired ear piece, plug it in, make a call, and then unplug after you end the call....that should resolve your problem...
Posted on Mar 18, 2010
My cells turns off as I turn it on!
Plug your cellphone in, your batteries could be shot.
Feb 26, 2010 | LG enV VX9900 Cellular Phone
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
Were is the sim card in an LG enV
Verizon's network does not use SIM Cards, only if you have a Blackberry and your going out of the country -would they give you one.
Since their phones are built to pickup CDMA signal, most of the phones don't have a spot for a SIM Card.. Because the phones can't pickup sim card signal..
But your local Verizon Wireless store can hook up both the phones to their system, to do a phonebook transfer for you! Or you can signup online for backup assistant through verizon. Backup assistant is where Verizon saves & copies your contacts onto the website - and then when you hook up a new phone, you use get it now to get backup assistant on the new phone, and it will copy the numbers over for you. If you signup online, it's free.
Mar 21, 2009 | LG enV VX9900 Cellular Phone
Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
My LG VX 5400 only works on speakerphone.
Do you have a Bluetooth headset? If so, your phone may have inadvertantly connected to your Bluetooth headset, resulting in no sound from the phone unless on speaker. You can test it out by making sure the Bluetooth power is off....from your phone's main screen, hit the "menu" button, then go to Settings and Tools, then Bluetooth Menu, then hit the "Set Off" softkey on the lower left side of your screen. If the softkey reads "Set On", then your Bluetooth power is already off. In that case, remove the battery while the phone is still on, wait 30 - 60 seconds, put the battery back in, power up and see if issue is resolved. If not, contact Customer Service for your wireless provider.
Nov 15, 2008 | LG VX5300 Cellular Phone
Can,t connect my Plantronics220 Earpiece to my phone
Begin with headset turned off. 1. Press and hold down the call control button
for 8 seconds until the headset status indicator begins to flash blue then red. The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing, use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
Oct 13, 2008 | Plantronics Explorer 220 Bluetooth Headset...
LG envy Bluetooth
sorry you cant as Verizon blocked this feature for some reason, though you can get the file off of the phone on to a computer and then send it to the rumor via bluetooth.
Aug 14, 2008 | LG enV VX9900 Cellular Phone
With use of Jawbone, recipients on enV get voice echo
About three months ago I bought the LG En V touch from a verizon store. I planned to use it with my old "New Jawbone" and my new "Jawbone Prime". The phone would nto pair at first then when they finally got it to pair I had a variety of problems. Verizon technicians performe a number of different steps trying to make it work as it was supposed to. They even reinstalled the software after about a week and a half I persuded the Verizon stor manager to replace the phone with a new LG EnVtouch and they exchanged my Jawbone Prime also. The new LG EnVtouch had the exact same set of problems. Neither of these phones worked any better with the bluetooth in my Garmin NUVI either. I loved the design and the features but if it doesn't work why bother. I returned the second LG EnVtouch after aabout five more days of frustration. And went back to my old phone. If you buy one of these and it doesn't work return it fast and let them know what you think!
Apr 20, 2008 | LG enV VX9900 Cellular Phone
Bluetooth problems
most bluetooth default passwords are 0000
it should pair up.
Feb 12, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
2,624 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
