Question about Amana SXD524VW Side by Side Refrigerator
SCD25TW Amana 1998
Where do I find the fuse feeding the icemaker? I don't have power to a newly installed icemaker. My diagram on the rear of the cabinet shows a fuse. I can't find it anywhere in the rear of the cabinet.
  • 410 Answers
The fuse for the i/m is actually in the wiring harness that plugs into the icemaker. if the model is correct the icemaker goes across the back of the freezer. when you installed the icemaker on one of the wires (i think red wire) there is a black "pill" looking thing. this is the fuse.
Posted on Feb 23, 2009
1998 buick regal stereo what are the wire color codes
showgif.do?image=73222
Connector Part Information
12110115
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
Dec 20, 2014 | 1998 Buick Regal
ICE MAKER NOT WORKING
Ice makers can be purchased inexpensively on ebay for about 45 dollars.
Otherwise the hassle can be caused by the solenoids feeding the unit water, the icemaker thermostat, heater element, cam motor, cam sequence, icemaker "off" switch, etc. Also check to make sure that the water line feeding refrigerator is working!
Nov 22, 2013 | Amana Side-By-Side Refrigerator 26 cu. ft....
1998 Ford Expedition with premium sound system. I removed the factory radio and installed an aftermarket radio had no sound coming from it, so I disconnected and installed the factory radio back in the...
Go to the engine fuse module and check 20A fuse 5 which feeds power to the separate amplifier and subwoofer amplifier. Also check 10A fuse 3 which feeds power to the radio, the CD changer, and the rear integrated control panel.
Oct 16, 2012 | 1998 Ford Expedition
I have an Amana Side by Side Refrigerator with an icemaker and water dispenser. I don't have a water line to hook up to the refrigerator. Is there an on/off switch for the icemaker?
There should be a stop control near the icemaker where it collects ice in the tray. It should be an L-shaped lever. move it to the stop position.
Oct 02, 2012 | Amana Refrigerators
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Mar 23, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Fuse block #33 immediatly blows the fuse. controls left tail light and about 4 other circuits. Problem started after my alarm started going off for no reason. 1998 323is coupe
According to the BMW manual circuit diagram F33 feeds power through the parklight 'on' switch to left front parklight and left tail lights (all grey/violet wire).
Suggest you remove all left side parklight bulbs, then check fuse does not blow.
If it blows without bulbs installed, check wiring/lamp sockets for short to earth.
Instal one bulb at a time, checking fuse status each time.
Perhaps spurious alarm problem is related to faulty alarm wiring- especially if the alarm is an aftermarket installation. Check quality of any spliced joints to the parklight circuit for possible shorts or water ingress.
Jul 10, 2009 | 1998 BMW 3 Series
GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Feb 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana scd25tw
It sounds like you have covered all the primary troubleshooting checks. There is only one thing I can think of at this point.
Check the voltage coming to the water valve during the icemaker cycle. The power to the valve is decreased by the resistence of the icemaker heater from 120 volts down to about 108 volts. It is not uncommon to have a valve that will open when you put 120 volts to it, as you do when you switch solenoids, but not open at the decreased voltage when it goes through the icemaker circuit.
If you are getting voltage to the valve when it cycles, and you know for sure the water line to the icemaker is clear, then you will need to replace the valve.
Post back and let me know what you find.
Nov 11, 2007 | Refrigerators
Amana SXD524VW Side by Side Refrigerator Logo
388 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
