Question about Sharp R-308H Microwave Oven
Sharp R-305KS door release problem
From moment of receipt, the door release push button did not have any resistance to release the door. Could the lever have been broken in shipment? Is this a replacement part? Where do you obtain the special hex type screwdriver head to remove the sheet metal housing?I have the same door release problem but after removing the screws I still cannot get the 'skin' to release from the front part of the machine. How do you get the stainless steel skin off without damaging it?
    Sergeant:
  • 326 Answers
Http://www.partstore.com/Sitemap/Sharp/Sharp/Microwave+oven+parts.aspx
click this link and enter the proper model number and get the required part which you require.
if the above link mentioned does not help then press this link directly http://www.alliedappliance.com.au/s/A17E405.HTM
1 more link for more help http://www.diy-spares.com/cgi-bin/catalogue.pl?section=141025&link_parent=67431&path=67430&shop=sharp
------------------------------------------------------------------------ for ordering spare parts http://www.gallawa.com/microtech/mfg.html
Sharp --------- 1-800-237-4277
Posted on Feb 23, 2009
    Brigadier General:
  • 5,158 Answers
Sounds like a spring has come off... you can get the hex screwdriver at any hardware store. and basically you need remove the outer shell off to remove the button.
    Scholar:
  • 165 Answers
Yes this can be broken definately and you can get the required part at.
http://www.applianceaid.com/nuker.html
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Jan 14, 2011 | Sharp R-1511 Microwave Oven
The door release button/handle doesn't travel far enough to release the door without pulling on the door
REPLACE THE PUSH BUTTON.SOMETIMES IT GETS WORN OR THE PLASTIC "***" HAS BROKEN OFF;COMMON PROBLEM.HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Sharp Microwave Ovens
Buttons don't work
Hello there:
This is normally caused by a faulty touch pad that is failing These touch pads are replaceable but they can cost about 60 to 100 dollars depending on the exact make and model ok
I hope this is very helpful for you
Best regards Michael
Dec 11, 2009 | Microwave Ovens
Latch button will not release door on Sharp R-5H84 microwave . Push button and can pull the door open with a slight amount of force.
Sounds like a portion of the release knob is worn or broken, or a metal piece behind it is bent.
Jul 26, 2009 | Microwave Ovens
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
My Sharp Model R 305 S, mfg May 2007, SN 228658,IS TRIPPING THE BREAKER. Less than a year old but I do not have receipt. Purchased at navy exchange, Annapolis, MD
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If that's model R-305KS, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The best place to order Sharp parts is Tritronics. Or you can call them at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Thank you for your service to our country.
Dec 19, 2008 | Sharp Microwave Ovens
Yes it is possible the door open lever got broken in shipping.
If your model has anti-tamper screws, you can remove them using using a T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler’s type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
Once the cover's off, you can see the door opening parts. It's probably the lever.
Oct 21, 2008 | Sharp R-308H Microwave Oven
I need Aan instruction manual for a Sharp Carousel microwave Model#R-305KS Serail #144439 RA67G2L
Hi - You can download the manual from the link underlined in blue below:
R-305KS
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 06, 2008 | Maytag Microwave Ovens
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Sharp R-308H Microwave Oven Logo
85 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
