Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Replace outer glass on door on oven.
I have a Frigidaire Stove model glefs77csb. I have the replacement part which is the outer glass on the door. I want to know any tricks on how to replace it.
Additional info:
Looks like there was small piece of double adhesive on each side where glass sits on door.
1 long single adhesive sided aluminum foil and 2 square single adhesive sided aluminum foil came with the glass. What do I do with them?
5 Suggested Answers
  • 125 Answers
SOURCE: Melted aluminum foil on bottom of oven
Steel wool is the best bet, but it would be easier to replace the floor panel. I had a customer do the same thing. depending on how bad it is replacement mat be a easier option, about $35 for the new panel, and about a month to get the part. two screws on the floor of the oven next to the back wall. The manual does say not to use foil on the oven floor.
Posted on Apr 18, 2009
  • 3230 Answers
SOURCE: melted aluminum foil
Good Luck!!
Thanks
Posted on Aug 23, 2009
colin324
  • 57 Answers
SOURCE: how do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Posted on Nov 04, 2009
  • 5370 Answers
SOURCE: I have a double over
You can try this only option.1 out 100 chance is there in this procedure. Use "Naval Jelly", available at most hardware stores or home depot-type places. Follow the instructions on the bottle, they're pretty straightforward.Naval jelly has internal acids in it.It reacts with the aluminium foil and loosens the foil from oven bottom surface.For some users it helped to clear this aluminium foil stuck problem.But if that is not helping then,Unfortunately, when the aluminum foil melts on the bottom of the oven, there is no way to completely remove it. The good news is that the bottom plate can be replaced relatively cheaply, usually for less than $30.00.You can call the manufacturer and order this part. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. This problem is faced by many others too.
------- NOTE:--If you have melted foil in the oven, do NOT run the self cleaning cycle on the oven until the part is replaced.If self cleaning cycle is run,then it will dame the oven. ----------If you are worried about food dripping and burning on the bottom of the oven, there are oven liners available that will not melt under the heat.A cookie sheet can also be placed on a lower rack to catch any drips or spills. You can get this from electrical appliance parts store. ------------
you can also get the required part from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Posted on Feb 07, 2011
Removal of inner glass door.. how.??
Open door to about 15~20 degree angle, pull up on door and totally remove from stove. Lay face down on flat surface. Now can access all screws to separate the inner and outer panels and to replace the glass. To return to stove, use locking pliers to pull the door hinge stubs out to their 15 degree open position, slide door on and close.
If glass not broken, just can't see through, no need to remove door or glass. Use glass cooktop cleaner, apply and let soak 3 minutes, then use new single edge razor in holder to shave off the baked on grease. May have to repeat 3x then switch to glass cleaner and clean again 3x, should be quite clean and clear unless seal has failed on the double pane thermal glass and internally obscured in which case the only cure is to replace the glass... return to paragraph 1.
Sep 20, 2015 | Ovens
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
The black tinted outer glass of my univa stove broke in pieces, can you replace it or make another glass the same?
Go to appliancepros.com and put in your model number and look up the glass. They will give you the price. I know on most models u can order the glass without buying the whole door.
Apr 23, 2014 | Maytag Ovens
The glass outer glass on my oven window broke can it be repaired? It's a Thermador Model# CT227NPRS Serial# 98020093
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 05, 2011 | Ovens
My outer glass shattered on lower oven
heatman101
Dec 11, 2010 | Ovens
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Broken glass front panel
Have the make and model number and contact any appliance parts supply, they can order the glass. or call a service man who can do it.
Nov 01, 2008 | Ovens
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Outer glass needs cleaning
yes. open door slightly to first stop point, pull up on door. the door will come off. there are screws on the bottom of the door and on the side facing the inside of the oven remove these screws to take door apart
Nov 18, 2007 | GE Profile JTP18 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
186 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
