you can obtain the instruction manual for this directly from the bosch web site free of charge if it is not listed there try the BSH Home appliances ltd site they are the manufacturers repair service in the UK
Steam escapes above door when cooking. I have cleaned the door and seals but the heat continues to...
(More)
Steam escapes above door when cooking. I have cleaned the door and seals but the heat continues to escape and the control above the oven gets too hot to touch
the outer glass door shattered BY ITSELF just 30 mins. ago......we have not used the oven in two...
(More)
the outer glass door shattered BY ITSELF just 30 mins. ago......we have not used the oven in two days and we were not using it or had touched it in any way!....frigidaire ceramic top, self cleaning oven..model fef364dwb.....almost two years old ....
Hi, my girlfriend accidently dropped a teapot (full of hot tea!) on our new Bosch hob and oven...
(More)
Hi, my girlfriend accidently dropped a teapot (full of hot tea!) on our new Bosch hob and oven (Bosch HBN 131 1.0 B). The clock mechanism on the oven started going crazy before I switched the oven off. I waited a while before turning on again and a faint buzzing flicker could be heard from inside the timer. I used the hairdryer on a coolish setting afterwhich some water came out after some time. We also turned the oven on at a relatively high heat and left it to run for a period. It seems to be ok now with everything working correctly but does anybody know if I should do anything else or should have done anything else? Thanks.......
