Does not boot to the Bios and to the hard drive.
The computer does'nt boot at all but there is power to the motherboard ans to the fan. The only thing I can hear the hard drive just spinning from the inside but nothing come out to the monitor.
  • 43 Answers
You might have a Mother board problem
Try changing you Ram with a new one
and if you are using a graphic card remove your graphic card and use the onboard VGA to see if the card is giving you the display problem.
and if none above solution is working you might have to test your motherboard but we have to go through this step by step.
Leave a comment on this problem so that we can test your board stp by step
Posted on Feb 23, 2009
When turned on will not start
hi
check the master and slave settings if you are using IDE hard drive.
if using SATA drive check bios setting is set to detect drives at boot up
some motherboards use ide settings for Sata drives
if this is not the problem check ram is inserted in the correct slots on the motherboard too
Nov 17, 2012 | IBM NetVista M42 PC Desktop
Hard drive not being recognised by compaq presario SR1975AN on warm boot
The hard disk may be running too hot.
The desktop case inside temperature maybe too hot. Check the power supply fan/CPU fan are operating correctly. You may need additional cooling in the desktop case an additional fan near the hard disk.
Mar 23, 2012 | Samsung SA07HD103SJ Samsung HD103SJ 1 TB...
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
I have an ASUS P5GLV-MX ACPI- computer. when I turn on my computer,sometimes it will boot up and sometimes it will not. it will just freeze up and sometimes it will say fan error or sometimes it will ask...
Sounds like a RAM issue, or failing motherboard.
However, first thing I'd do is boot into the bios and set the bios to "defaults" or "optimum defaults" or whatever safe-defaults option there is (might be in the last tab/menu/page where you exit or save). Sometimes we inadvertently make a change in the bios which causes issues like this, and resetting things to "stock" settings will fix this.
The CHEAPEST and first thing after that I'd do is replace that bios battery (Cr2032 as I recall).
Then I'd download and reinstall the Bios, if the problem persists.
This is often what happens when small things begin to fail on a motherboard. It could be the battery, or a small regulator circuit or diode for timing or RAM or bios functions. I've got some older machines that do this everytime I shut them off. I've replaced the bios and battery and that fixed it many times.
The troubleshooting can be too tedious, even with newer motherboards and gear. If you're set on continuing and these things don't fix it, pull EVERYTHING off the motherboard except the cpu/heatsink fan and one stick of RAM (no optical drives, no hard drives, no peripheral PCI cards). If that doesn't fix it, then change the PSU or swap it out to make sure you're not dealing with an inadequate power supply to the motherboard (faulty PSU's cause all kinds of odd problems to computers).
No luck, replace the motherboard.
Sep 05, 2010 | ASUS Computers & Internet
Gateway GT5220 bios works no boot up
If the issue was the video card then there would be no display. If there was any display it would be discolored.
Try unplugging any removable media that's hooked up to the computer. After that try to boot it up.
If it still doesn't go anywhere then you most likely have a power supply issue on your hands. try unplugging an unnecessary components inside the computer such as any CD/DVD drives and removing any cards installed. Pretty much everything but the motherboard and the hard drive. If it still doesnt boot properly then you might either have to buy a new power supply or a new motherboard as long as you know your hard drive is good.
The thing si if it was an issue with the hard drive you would get an error message. If you seemed to have left out any error messages please post them.
Jun 07, 2010 | Computers & Internet
Os install won't let me
Okay, this is elementary, but I've forgotten some pretty basic things before.
1. You've cleared the RTC?
2. Made sure you have the latest bios copy in it?
3. Gone into set up and set the computer to boot from the DVD before the hard drive? (If it's set to still boot from the hard drive first, it won't boot up)
4. Made sure the drives are properly defined?
By the way, does NT 4.0 run on Fat 32 or NTSC?
You don't happen to have a master/slave problem the way your drives are set up do you? Just trying to think of anything that might foul the install.
I think it sounds more like a hard drive problem with the way it is set up rather than the motherboard. I hope that is the case. Let me know how it goes.
May 12, 2009 | Abit A17 Guru Motherboard
Main bios checksum error
You have to change the CMOS battery located on the motherboard...
Mar 28, 2009 | Computers & Internet
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Motherboard Question
either the power supply or the motherboard itself failed. it's quite difficult to say which one produces the problem without testing.
Mar 23, 2009 | Dell Precision Workstation 670 PC Desktop
Still the same problem will not boot
high im josh in cebu phils. the computer will not boot only power A lot of things could be causing this ,try process of elimination,open case ,remove all addin cards except video ,diss connect cd drives and floppy ,unplug mouse and keyboard and boot computer keep adding things back in.one by one put the hardware back in.be sure you conected properl the hardisk. or if still go to bios setup menu then choose boot settings.select hard drive to boot first then save the changes then reboot your pc. good luck
Feb 21, 2009 | ASUS A8N-SLI Deluxe Motherboard
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
