Question about Star Manufacturing 86S Popcorn Maker
Stirrer motor not running - Star Manufacturing 86S Popcorn Maker
    President:
  • 1,489 Answers
Most likely the motor will have to be replaced. This is probably a case of where buying a new popper is cheaper.
Posted on Apr 22, 2009
The oven has trouble ligting,and make,s a boom sound when lighting
Magnetron
If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Enter your model number to see parts for your microwave.
Help me find my model number
Exhaust Fan Motor
If the microwave is loud when running the fan motor might be
Stirrer Motor
If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor
If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Apr 02, 2013 | Microwave Ovens
Coleman EB15A - Buzzing noise from transformer area, no heat or fan
see this causes and proceed. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 18, 2012 | Microwave Ovens
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
Oct 15, 2012 | Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
Oct 10, 2012 | GE Microwave Ovens
Stirrer Motor Part Number PS237771 GE Microwave
Quite possibly the Stirrer/ antenna motor. To Replace that, the outer cover of the machine must be removed. Unplug unit and take off the screws on the back of the unit and pull the cover back toward you and it will come off. The antenna motor is on the top of the unit and is only held on with 2 screws. You take off the two screws and lift it off of the unit. when replacing it you have to make sure the antenna is properly positioned on the shaft of the new motor to make sure it will turn properly. Not a difficult repair.
Oct 30, 2017 | GE Microwave Ovens
Help - the stirrer keeps sticking, the motor strains to turn it round but it won't go when the dough is in, its too heavy. The last loaf I made I had to take the dough out of the machine and kneed it...
Take the bread pan out of the machine and run a kneading cycle. See if the motor is straining. If it is it could be a belt or the motor itself. If the motor runs nice and smooth and you can see the motor shaft spinning effortlessly, then it's the bread pan itself. See if you can spin the paddle easily when it is out of the machine. If not then it is the sealed bearing in the bread pan that is starting to fail and it's time for a new bread pan. Hank
Dec 13, 2009 | Kitchen Appliances - Others
My Whirlpool microwave model MH9181XMT started making a loud noise while running (it sounds like a wobbly fan) It continues to heat and run perfectly but with the noise. Any ideas?
Assuming you already ruled out the exhaust fan there are 2 stirrer motors, one for the turntable and one for the stirrer blades in the top. One of those could be bad. eric
Aug 05, 2009 | Microwave Ovens
Motor turns but gears seam to be slipping
I would look for screw that has loose up and that's proablly why the stirrer will not turn.
Mar 21, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Stirrer motor
Pricey little thing I have checked 3 places all say it is NLA I will post it on a nationwide parts order to see if anybody may still have one one in stock
Jan 23, 2008 | Hotpoint RVM1625 Microwave Oven
Star Manufacturing 86S Popcorn Maker Logo
155 people viewed this question
Top Star Manufacturing Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Star Manufacturing Kitchen Appliances - Other Expert? Answer questions, earn points and help others
