Question about RCA 25403RE3 Corded Phone
Rca phone receivong error inhibited after the plantronics base ..
RCA Visys phone model 25425re1 when i hook up my plantronic wireless headset to it all i get is error inhibited, the headset button on the will not work
2 Suggested Answers
SOURCE: How to configure call forwarding on RCA RCA Phone model 25425RE1-
CALL FORWARDING HAS TO BE DONE THRU THE PHONE COMPANY IF YOU HAVE CALL FORWARDING - AND I DO THIS IS WHAT I DO - I HAVE AT&T IN MEMPHIS TN PICK UP HAND SET AND HIT *72- YOU WILL GET A BEEP- DIAL THE PHONE # YOU WANT TO FORWARD THE PHONE TO - SOMEONE MUST BE AT THAT PHONE NUMBER TO ANSWER IT! ONCE THE LINE IS ANSWERED- THEY HANG UP AND THEN YOU HANG UP AND PHONE SHOULD BE TRANSFERED- I ALWAYS TEST IT TO UN- TRANSFER IT PICK UP PHONE AND HIT 73# AND IT WILL BEEP 2 TIMES- NOW PHONE IS NOT TRANSFERED ANY MORE
Posted on Jan 25, 2009
Can't hook up the Plantronics 320 with my Pantech phone . Is the pass code 0000 ?
For all current Bluetooth headsets the passkey is 0000 (four zeros).
If the phone does not accept this code, please refer to your cell phone user's guide to ensure the proper setup procedure.
Note: Powering your cell phone off and on sometimes corrects this issue. You cannot change or personalize the PIN code/password of the Bluetooth headsets. It will always remain four zeros.
There is a link below to the Plantronics 320 User's Guide which may help you also.
Good luck from Headsets Direct!
Jun 25, 2011 | Plantronics Explorer 320 Wireless Headset
I have a CS70 NC./ no lifter. What is the set up procedure to use my headset without lifting my phone handset. With the base plugged into the headset port of the phone.
If the Plantronics CS70N wireless headset is plugged into the headset jack on your phone, you will need to push the headset button on the phone and then the call/control button on the wireless headset.
Jun 10, 2011 | Plantronics CS70 Wireless Headset
Plantronics CS70 is paired with the Yealink EHS36 it will not pick up the line, you can hear nothing but the EHS36 clicking
You are using a Jabra Electronic Hook switch with a Plantronic's headset, they are not meant to go together. Depending on what phone and model you have would depend on the EHS that you would need.
Plantronics HL10 Handset Lifter
May 05, 2011 | Plantronics CS70 Wireless Headset
Plantronics explorer 232, connected but no sound through headset
I had to power off my cell phone and then power it back on. That solved my issue.
Jun 02, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Is it compatible with an IPCC nortel network phone?
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
Jun 02, 2009 | Plantronics CS60 Wireless Headset
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
My bluetooth
Sorry I post the wrong link before, for plantronics manual it is: http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
Jul 31, 2007 | Plantronics Explorer 320 Wireless Headset
RCA 25403RE3 Corded Phone Logo
844 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
