Question about Apex Digital AT2708 27" TV
Won't scan all cable channels.
How do I get TV to scan all cable channels. Have only used the external anten. before, but now want to hook it up to cable. Can't find manual. I can only get it to scan a couple of channels instead of entire cable offering. How do I get it to recognize full cable access?
  • 4,234 Answers
I don't know your exact model, but from your description, the set is still in the over-air mode. Check the setup menus for a setting for cable/air and set it to cable. Once that is done, the autoprogram should work. Many of the newer models will scan both options at in sequence, but not all. Let us know if that does not resolve the problem.
Dan
Posted on Feb 23, 2009
NTD-1356 Auto Channel Scan not finding channels
Cable TV comes from the receiver to the monitor (ntd 1356) thru a cable the ntd 1356 tuner needs the external antenna to be installed to work
Check the inputs for external signals
Oct 29, 2016 | Televison & Video
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
How do I switch from cable to external anten ae
Is it a satellite antenna or regular outside antenna ? What kind of cable do you have? Is it dish network or cox, cableview, radio shack?
Aug 15, 2013 | Toshiba Ct885 Remote Control
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
I cannot getter than 22 channels? I've scanned and
Are you using Antene or Cable? you do need to Select cable.
Or the PLL circuit is not working
Nov 01, 2012 | Televison & Video
Connected lg tv directly to cable wall jack. Can only get one channel. Manual scan grayed out. Ez scan does not find any channels. Main input is set to cable box. No option for just cable
Why not get a box and hook via rear inputs--not that expensive from most cable companies. If items such as the channel scan are grayed out it means something in the set is set wrong---
Apr 21, 2012 | Televison & Video
My tv will scan and receive channels on a antenna but will not pick up channels on a cable scan with a good cable and a proven good cable signal
if you are not using a cable box and trying to connect cable directly to tv you will get very few channels since they are all digital now and most are scrambled
you will need to hook that cable to the input labled 'QAM' and program tv for digital channels
if you are coming out of a 'cable box' you just need to hook up video cables to an input on tv and change tv to that input - no scanning necessary
hope this helps - if not write back with more details and i will try to help more
good luck!
Mar 25, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Not able to scan for digital OTA channels on a JVC LT-32X667 LCD
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
Aug 23, 2009 | JVC LT32X667 32 in. LCD Television
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
Problem with my ltv-19w6 flat screen TV
hi your tv will  not show picture if there is no cable or antenal connected insted it will show u the blue back baground
Sep 29, 2008 | Westinghouse LTV-19w6 Television
Apex Digital AT2708 27" TV Logo
899 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
