Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Wiring Diagram Maytag LSG7800AAW Washer/Dryer worn & unreadable
Hey. I removed, cleaned, lubricated and replaced the dryer motor on my secondhand Maytag LSG7800AAW Stacked Washer / Dryer but I'm having trouble reconnecting the wires to the 'hub' where the dryer motor and door safety switch, timer, etc. come together. There are colored dots on the front of that 'hub' but I seemed to have wired the 'buzzer' on instead of the motor. I can usually follow a wiring diagram but the one inside the panel is too worn to follow and the number of wires coming together here is a bit confusing.
Please help 'cause my better half keeps reminding me the dryer is broken.
  • 2 more comments
  • crodie Feb 25, 2009
    Hey mlord4,
    it's a timer and wires from motor are light blue... the 'hub' is only a 1" x 2" x 1/4" thick plastic piece that has about 9 'tab style' male electrical connects exposed.
    This piece is attached to the motor so to replace it I had to unhook the wires to the door switch and other relays which tell the motor to stop.
    help????
    thanks
  • crodie Feb 26, 2009
    Hey... update.
    The wiring in question goes to the 'centrifugal switch' mounted on the motor.
    -from the motor come: 1 yellow 1 blue 1 black wire
    -inside the dryer compartment: 1 red 1 gray wire
    PLUS these combos which are 2 wires each connected at a single lead each: Black/Brown... White/Blue... Yellow/Light Brown
    There is a tab on the switch with the # 3-3877 as well as a Black Yellow Blue Grey and Red Dots which correspond with male leads.
    Top Row Left to Right:Black/Yellow/Blank
    Bottom Row: Blue/Grey/Red
    So what goes in the blank spot? Where do the combos go?
    There are 8 wires and 11 spaces.
    This machine was built to get me committed.
    crodie
    ps- I live 80miles from any professional.
  • mlord4 May 11, 2010
    i have not found my book of diagrams yet .if this dryer has timer & is about 15 years old i do not rember relay for motor has 5 wires on motor switch to change motor you should just take wire off motor i am still not shure what you did i will try to get diagrams & help
    what is the hub. wire on motor are colored check wire on motor .is a 7800 touch pad or timer i can remebe how old is this unit i will try to find my wiring diagram
KevinWhite
  • 1902 Answers
SOURCE: I have a LSG7800AAW stacked
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing.Please get back to me if you have any other questions.
Kevin
Posted on Aug 16, 2011
  • 5 Answers
SOURCE: Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
Posted on Jun 23, 2008
CRTN
  • 716 Answers
SOURCE: Maytag LSG7800AAW Dryer not working
Its Either One Of Two Problems If Its Electric Its The Thermostat but if its gas it can be either the thermostat or the igniter. If its gas you can watch the igniter or listen to hear if its lighting. If it lights its the thermostat cause if the thermostat is malfunctioning it will turn the gas off when it doesn't detect the flame. It turns the gas off to prevent your home from filling with gas. Hope this helps.
Thanks For Choosing Fixya
Sincerely,
Michael Scott
Posted on Jul 07, 2009
SOURCE: Maytag Neptune mah4000aww has a broken door
Black - common, gray - NO, orange - NC. Wiring diagram is inside the control panel
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: maytag LSG 7806 Electric Dryer doesn't heat up how
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
2yr old maytag maxima dryer gets louder and louder after run 30min. prob. repeats after cool down and running again. Vent is clean new pipe, no error codes. Sounds like a surging vibration.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Apr 06, 2015 | Maytag Dryers
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
Model no. LDE8506ACE has a noise when running seems like maybe drum rollers or belt. how do I get to drum?
This link is provided by www.repairclinic.com and shows parts breakdown/disassembly procedures, etc.
A faulty blower could also cause a noise during operation and as the motor slow rpms on stopping.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Aug 18, 2009 | Maytag Dryers
Maytag Gas Dryer LSG7800AAW makes noise at start up
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
789f
Aug 03, 2009 | Maytag LSE7806A Top Load Stacked...
Need a wiring diagram for a maytag gas dryer dg312
If the old motor is still installed simply change wire for wire.
Jul 27, 2009 | Dryers
Sincerely,
Michael Scott
Jul 07, 2009 | Maytag LSE7806A Top Load Stacked...
Need to know age of stackable
I purchased mine brand new in 1993.
May 27, 2009 | Maytag LSE7806A Top Load Stacked...
How do you access the blower wheel on a maytag stackable dryer. I have the LSG7800AAW, the housing is on the lower left but after removing the four hex screws the housing does not come off. Can anyone...
after removing te front panel you can see the blowe rwheel inside hte housing, probably 6 1/4 hex screws holding sheetmetal face on housing as well as to 5/6 hex screws holding motor down
Dec 03, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Sep 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
764 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
