Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag dryer dryer tries to start, but just goes thump and gives fault code E6. Donnie
  • 6,784 Answers
• Be sure the door is latched shut.
• Be sure the power cord is plugged into a live electrical outlet.
• Check the home’s circuit breaker and fuses.
• Press the START button again if the door is opened during the cycle.
If everything checks out ok with the above check list, you may have electrical motor issues. I would run a break point test on the motor and the control panel as well. (You will need a Voltage needle to perform a break point test.)
Posted on Feb 23, 2009
Why is my Maytag Epicz model #MGDZ600TW2 not starting and giving me an error code F01. What does it mean?
The F01 error code is typically a communication fault. You may have a defective main control board. Unplug the dryer or turn off the breaker to the dryer. Double check to make sure dryer has no power. Remove the screws holding the top on at the back of the dryer. Standing in front of the dryer push down and slide the top away from you then lift. With the top removed you will see a metal bracket on the left side housing a control board. Remove the control board from the bracket. You may want to take a picture to reference where the wires go. Remove the white cover of the control board then gently remove the control board from the white housing by pressing in the small tabs. If you see a black mark on the back side of the control board and the white housing replace that control board. According to your model number the main control board is part number W10111606.
Jan 29, 2015 | Maytag Dryers
What causes a thumping noise when a dryer is started?
Most of the time its the drum rollers, If they never been changed they are due.
Oct 01, 2014 | Maytag Dryers
Maytag dryer tha-thumps
It is safe to use the dryer, I don't see any foreseen future to other parts. But the idler definately is flat(tening). It should be replaced asap.
May 24, 2012 | Maytag Dryers
Thump
The drive belt broke and the thumping was caused by a flatten roller on the belt tensioner. Replace the tensioner pulley and the belt to get it running like new again
May 25, 2010 | Maytag MDE9700AYM Electric Dryer
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Washer fills with water, loud thump sound, no agitation occurs.
The thump is probably the motor trying to start followed by the burning smell of the belt slipping. See if something is jammed, but the most likely thing there is a bad transmission.
Dec 31, 2009 | Maytag LSE7806A Top Load Stacked...
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
My new dryer thumps every revolution
Flat spots on the support rollers from sitting in storage will make a thump. So will heavy wet clothes if they are not spun dry enough from the washer. This may lessen as the unit is used but since it is in warranty a service call to rule out major problems is in order.
Eric
Jun 17, 2009 | Maytag MDE9206 Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
128 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
