Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
My kenmore washing maching door is not opening
My machine He 3t model door is not opening please help
    President:
  • 1,294 Answers
Hold in "end of cycle" for 3 seconds. Or if you have a pic of a "key" on one of the buttons, hold that in till the lock signal goes off.
Posted on Mar 13, 2009
Where can I find a door latch for the Kenmore HE 3t
"Fdl" is a door latch error code. This is an indication of either a defective door latch, door catch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
Read through the information provided and post back with your complete MODEL NUMBER if you have questions. I hope you find this information helpful.
Jul 19, 2010 | Kenmore HE2 Plus Front Load Washer
The door won't open. There are no error codes displayed. I have a Kenmore Elite HE 3t.
open the bottom panel by unscrewing 3 screws. reach up towards the door lock and pull a level to manually unlock the door.
Aug 17, 2009 | Kenmore Washing Machines
He 3t error code f6,washer will not spin,door will not open
"f6" error code means that there a miss communication between mcu(motor speed control board) and ccu(central control unit). i recommend you to ohm out the motor. most likely its your motor speed control located at the bottom left of the washer good luck. replace the motor speed control board and you should be all set to go.
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code 32 on a brand new Kenmore HE 3T wash machine
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machine door latch replacement
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
Jun 18, 2008 | Kenmore 4292x Front Load Washer
Lights on Front Panel Flashing
Another posibility is the door lock switch is broken. When you open the door, on the middle right hand side there should be a small pin sticking out from the washer that the door pushes on.
Jun 13, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
82 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
