Question about Compaq Presario R3000 Notebook
Compaq Presario R3000 shuts off by itself in about 20 minutes! I have to restart each time. Could someone please suggest a solution.
  • 1 more comment
  • Thapi Mar 08, 2009
    My Presario R3000 Notebook is automatically powering off and when press the power button Notebook is starting.
    Please help
    Thanks
  • dgarkie May 11, 2010
    if it as simple as i think it is this might help when i bought my laptop the power saving options were set to shut down after 25 mins of idle time try going to power options if your computer runs vista and has a batery display down by the clock right click on that and go to power options then click "choose when to turn off display" then change the time under put the computer to sleep tab to whatever you want if that doesnt work there is something else
  • My reply is May 11, 2010
    Does this only happen when running on battery or as well when using AC adaptor?
It is most likely a bad thermal control chip (or connection to it) on the motherboard.
Options:
1. Attempt to reflow the motherboard/replace thermal chips (or have a pro do it).
2. Get a new motherboard ($80 to $100).
Option 1 probably cost more than option 2 unless you have a local repair shop where you can just drop it off.
Replacing the motherboard isn't very difficult...just time consuming.
Here is a link to the service manual:
http://www.hp.com/ctg/Manual/c00212209.pdf
Or:
Set the unit on ice packs or an air conditioner vent...it'll probably run for weeks if you can keep it 'ultra cool'.
Posted on Jun 21, 2009
  • superfluousj Jan 21, 2011
    I have the same problem. Obviously not enough air flow to keep it from over heating. A simple solution for me was to use a wire "cookie cooling rack" to raise the computer off the tabletop and reduce the heat. Never had another problem.
  • Richard Eisenman
    Richard Eisenman Feb 12, 2011
    For my Presario R3000, I don't think its overheating. There's no temp monitor shown in the BIOS. And my power cord is definitely OK.
    It would erratically just turn off with no warning.
    My solution: in my 'Portable/laptop' Power Scheme, set EVERYTHING, batteries or plugged in, to NEVER.
Uninstall the bios driver first and power it back on it might help
Posted on Apr 29, 2011
Compaq presario r3000,bios problem restart.plesase resolve
Did you install any software's or re installed the operating system?
Dec 25, 2010 | Compaq Presario R3000 Notebook
Compaq presario r3000 laptop monitor problem
You have a bad LCD area on the monitor. You can replace it yourself or take it to a repair shop.
Mar 16, 2009 | Compaq Presario R3000 Notebook
Compaq r3000 dark screen
If you already replaced the inverter and the screen still continues dark, you need to replace your lcd screen. Your video card is good due you have signal with external monitor.
Sep 18, 2008 | Compaq Presario R3000 Notebook
Compaq Persario R3000
i have a problem can you please send me a atachment of this driver base system device so i can instal it to my laptop compaq presario r3000
my email is sogunade@yahoo.com
Sep 04, 2008 | Compaq Presario R3000 Notebook
Presario r3000 shuts down
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
May 04, 2008 | Compaq Presario R3000 Notebook
Laptop won't stay on
it might as well be a internal problem related to power or loose contacts with RAM or the power chords internally.
Better to go to the technician in this case.
Your first Battery would have been fine too..
Apr 12, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 (intel) 2800 Reset 4 or 5 time a day
Kees,
It sounds like you have fried motherboard. If that's the case, you have to get it serviced by a place your manufacturer recommends. Sometimes the cost can be greater than just buying a new laptop, so shop around and see what you can find price-wise.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Compaq Presario R3000 Notebook
check the battery that powers your cmos. if your laptop is like my compaq armada, there's three screws at the top which free up the keyboard cover. there are three latches near the bottom of the keyboard. the keyboard swings up towards the top. there's two film type connectors in the middle of the motherboard. pull these out and the keyboard comes free. look in the upper left part of the laptop for a small disk type battery with a red and black on white nylon connector. replace this battery. it is a lithium-ion battery.
Dec 07, 2007 | Compaq Presario R3000 Notebook
No display
Re- boot the computer, see if it will come back on again.
Go to start- click on log off -than click on restart it will shut down and back up again .
If this dont help try going to re-store - go to the calendar click only on 1 of the high lighted areas , Should put ya back on.
Nov 29, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
768 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
