Question about Zenith B27A11Z 27" TV
Red screen Hi my tv screen is turning red and the tv is sparking and is turning red .We need repairment fast so we need to know if something is unpluged in the wall or is it the tv ?
    President:
  • 2,992 Answers
Sorry to say, you need a new TV. The picture tube is bad, and allowing high voltage to feed back into the set where it shouldn't go. It would cost more to replace the picture tube (and probably the circuit board as well, as that usually gets damaged too) than a new TV.
Posted on Feb 23, 2009
Bravia kdl-32l5000. Why does it have a red screen?
Color circuits are messed up and need repair.
Mar 05, 2016 | Sony Televison & Video
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Lacking red
Hi
in this case you have defective CRT Circuit System, CRT means The Cathode Ray Tube... Circuit system. this need to diagnose the System IC. if you know how to repair electronics appliances i can teach you how to fix this issue..
Thanks!
Jan 14, 2009 | RCA F32695BC 32" TV
SPN4235 TV -- red light blinks but picture doesnt come on.
being that it fell , this is already a bad sign that the screen is dammaged and it will need to be tested and looked at to see what other dammage has happen to it
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung hdtv HLP5085wx no image. Smelled something burning and sparking, turned off the tv. Tried turning it back on = have sound, NO image!
OMG! Dude, your screen is just plain fried. You don't need a new screen though, You just need a new bulb for it. See, behind the screen is a light bulb (unless your T.V. is plasma screen), sometimes two or three, and that burning smell was the bulb blowing (like when you need to replace a light bulb in a lamp or something). I don't know where you can find a new bulb, but once you replace it everything should be fine.
Oct 05, 2008 | Televison & Video
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Screen doesn't come on, but sound does!
Hi There!
Sony TVs are very difficult to assess at first, so one would first need to know how a TV works and then the experience that goes with it. Every model is different and has different faults that make them NOT work. I would recommend to have it repaired by a technician. I dont think this is something you can do with a remote or on the unit. It is internal. Good Luck, JUS004
Mar 05, 2008 | Televison & Video
Red screen and only red bulb powers on.
The red tube and the red crt board sound like the problem. these would be the first thing that needs to replace 250 for tube +50 for crt board. + labor about 300 to 500 to repair
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
AverKey3 Plus
Hi, sorry to tell you this, but static electricity has killed every conceivevable type of electronic device ever built by man or woman. The insides of your TV has very high voltage and the only safe solution is to take it to a repair man. Ask for a qoute before any work is done, try to get at least 2 quotes.
It may be cheaper to replace than repair the unit and with 2 quotes you will know that you are not being conned.
Regards mistyman
Oct 09, 2007 | Avermedia AVerKey Plus (AVERKEY-PC)
62 in. DLP Toshiba model # 62HM14
Hello, This is a problem that a lot of sets are having the overcurrent protection circuit is turning of the set dur to components going bad and drawing excessive current. Now the fix of the day is to replace the two convergence modules, but I am begining to think that something is seriously wrong with these sets and by just replacing the convergence modules you are actually hiding the problem rather then fixing it. So I would ask that you take this set to a qualified tv repair shop, and ask them for a repair report on the work done to get your set working and why did they take the action that they did. But if you just want to get the set up and running here goes the parts that have been failing are the two STK392-110 replacing these "fix" the problem at times. Some forums even have folks replacing the stk392-110s with the STK392-150s, let me warn you, this upgrade requires the changing of the bias resistors, and I would advise you to get a schematic, in aiding you in your quest to repair this set. I know that this might not seem helpful to you but it actually is.
Sep 13, 2007 | Toshiba 55H70 55" Rear Projection...
Zenith B27A11Z 27" TV Logo
57 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
