Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
I have my grandmother's old Kenmore 1814 sewing machine
When I push the foot petal it moves very slowly and I get a burning smell. I manually turn the dial and it is very hard to turn. I would also love to find a manual; I don't have one. Thanks!
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
kent581
  • 87 Answers
SOURCE: My Husqvarna Viking 980 continues to sew when I
I have never seen it be the circuit board, always is the foot control switch. I dont understand the stitch getting tight though. And yes, it could be the circuit board.
Posted on Mar 19, 2009
SOURCE: start/stop button problem will the machine run on its own
You have to unplug the power cord to the the foot pedal. The manual doesn't include this. And good stinkin luck with Sears or Kenmore customer service! Just pull the cord out of the machine and the start/stop button will work. Try it on a slower setting at first though. Also, if you need additional presser feet, Singer, Brother, Janome, and possibly other brands will usually work as long as they are the snap on type. I really do like my machine, good luck with yours!
Posted on May 05, 2009
  • 130 Answers
SOURCE: it keeps sewing after the foot petal is let off -
Sounds like the foot petal needs to be taken apart and cleaned. Make sure everything is unplugged. Use WD-40 on everything except any electrical parts, it has chemical  agents in it that break down the plastic after a long period of time.
Posted on Jul 31, 2009
Whenever I plug it in & turn it on and push the foot pedal all it does is hmmmm. The needle doesn't go up and down. Answers to why this is?
***Check to see if the bobbin threader is in the on setting.
***The motor or the main shaft of the sewing machine may be stuck.
***Turn the hand wheel. Does it turn with ease and move the needle at the same time?
***Take the cover to the motor off. Check the belt. Replace if necessary. When replacing it is necessary to push the foot pedal slightly while setting the motor to move the belt to it's easiest and fastest position.
***If the motor/belt is good then you will have to investigate the main shaft. Remove the top cover and look at the shaft going through the machine. Place drops of oil on any parts that move. Use only sewing machine oil !
***Under the machine remove the cover and place oil on moving parts.
***If you want to clean it is a good tool to use q tips. Between gears use silicon grease.
***Do the front of the machine the same. Clean and oil.
***If your machine is really stuck due to rust you will have to do some serious cleaning. Use carburetor cleaner for this. Always work in a well ventilated area. After allowing this to set you may have to force the hand wheel to turn.
Good Luck!
Sep 30, 2015 | Sewing Machines
My sewing machine electricity is on but it only growls when i step on the foot peddle. Is the motor froze or what can I do to make it work
Depends on your sewing machine brand and model. If it is an older mechanical (NOT computerized) model. It could very well need cleaning and oiling, as the old oil has solidified and the motor is unable to turn the mechanical parts. Do not continue to force the motor to run as it may burn out.. Consult your owner's manual under the maintenance section for instructions. Use ONLY good quality sewing machine oil, NOT 3-in-1, WD-40, cooking oil, or the oil can from your grandmother's sewing basket.
Aug 30, 2015 | Sewing Machines
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
I recently was given a Baby Lock Esante ESi-2 from my grandmother. She just gave me the machine. I dont have a manual or anything but the petal and power cord. I dont know what i need to run it or even how...
AT LEAST you have the petal and power cord - I had to order that from a place in online at sew4less.com - the foot petal was 49.95 and the cord was 14.95. I see a slot in the side of mine and it's for a memory card - those are 119....
Jun 09, 2009 | Baby Lock Esante
Old kenmore sewing machine model # 1237 ( not found in search) - prob. purch.'d in 198o's
Check the handwheel. If it is pulled out, the clutch is not engaged. Try pushing it in! (It would be really nice if the solution is this easy!)
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
62 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
