Question about Swisher ATV Postmaster Trimmer 6.75 HP
Trimmer line for Swisher ATV Postmaster Trimmer. What to use and how to attach
  • 42 Answers
I have found that you can use any kind of trimmer line that you want, but the size has to be .155" trimmer line. Also, below is a website with the manual for your postmaster. I was also wondering how you liked your postmaster? I am really thinking of getting one. I run cattle on about 8-10 miles of electric fencline and am always having to take the handheld trimmer to the fenclines to clean them up so the electric fences don't get to bogged down. Let me know. thanks. below is the website.
http://www.swisherinc.com/manuals/PDF/ST/PST04.pdf
Posted on Mar 15, 2009
Laawrenceburg, Ky. I thought I was writing to the postmaster, sorry
Address the envelope and letter to the postmaster by using the title "Postmaster" with the full name of the person. For example, Postmaster William Duvall. He is the most recent postmaster in Lawrenceburg that I find a record of.
Write the first line on the envelope, "Postmaster at municipality name and/or zip code."
Continue by filling in the name of the street where the post office building is located.
1269 Fox Creek Rd, Lawrenceburg, KY 40342
Write in the name of the town, state and zip code to finish the Postmaster's address.
Oct 21, 2017 | The Computers & Internet
I am trying to send emails to yahoo account in Crete and I keep getting back cannot be delivered and go to postmaster,what do I need to do?
the postmaster is the server that your e-mail is delivered to to get to the recipient
if the e-mail address is not correct in every detail, that server ( postmaster ) will deny it and send back that message
the address has to be exact in case , underscore, punctuation, spacing or no spacing etc
even a comma before the address will get that response
one way is to find an e-mail from the address you are sending to , and copy/paste it in the address line or if you are using a contact me -email address copy/paste it in the receiver line
if you open up the message from the postmaster , it will explain possible reason s for non delivery
Sep 28, 2016 | Yahoo Computers & Internet
The primer bulb doesn't fill with gas
sounds like you hasve a cracked fuel line or a cracked primer bulb. that is why it cant prime.
Aug 29, 2015 | Swisher 190cc 22" String Trimmer Mower...
Swisher E4 (lack of power and rpm) ???
Hi Davis:
Check exhaust/muffler. Make sure it is not obstructed with carbon.
Check trimmer string is not too long.
Check air filter. Make sure it's clean
What is history? Was it running well and then something specific happened?
Spark plug - how long since it's been changed?
Hope this helps.
May 01, 2015 | Swisher E4 Shindaiwa 245cc Commercial...
Gas is leaking from the primer on my swisher walk behind trimmer. What would cause this?
i believe you have a cracked primer bulb or cracked fuel line. you should also check and see if the screws are loose that connect the primer bulb to the assembly.
Sep 25, 2013 | Swisher Walk-Behind High-Wheel String...
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
Gasoline in the airbox, muffler (2006 Suzuki Vinson ATV)
usually when the needle and seat are stuck, the gas will run out of an overflow on the side of the carb, unless those are plugged for some reason, then obviously the gas will flow where ever it can. is the machine 2 or 4 stroke?,
May 31, 2009 | Swisher Atv Tru Plow
Swisher ATV Postmaster Trimmer 6.75 HP Logo
381 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
