Question about Amana NDE2335AY Electric Dryer
My AMANA electric drier will not heat
My AMANA electric drier LEC20AW will not heat
I replaced the element and it still does not heat.
  • Amana Master
  • 3,361 Answers
Verify 220 volts to the terminal block where the cord connects.
If 220 is there, unplug the dryer and check the thermal fuse and hi-limit thermostats on the dryer cannister.
Posted on Feb 22, 2009
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
My Amana 7200 Dryer will not heat???
Heating element in drier may be burnt out.
Nov 12, 2012 | Amana Dryers
It's not heating and we've replaced to different heating elements
the dry is not heating up. we replace the heating element and thermostat and thermal fuse., It sill doesn't heat up
Nov 10, 2011 | Amana ALE866SB Electric Dryer
Heat element burnt out replaced with new, still will not heat
one of heating element burns out how can i replace it? amana brands cooking range
Apr 03, 2011 | Amana AER5515QA Electric Kitchen Range
Strucke
If the drier is electric then more than likely the heating element has burnt out. This element is located at the bottom of the drier and can be accessed through the back. The element looks just like a toaster element. Take the model and serial #'s to an appliance parts house for the correct replacement part and you should be good to go. It is fairly simple to replace as you will see once you take the back of the drier off
Good luck hope this helped
Dave
Feb 24, 2010 | Kenmore 500 6952 Dryer
Replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Dec 11, 2009 | Amana ALE643RB Electric Dryer
No heat electric drier..dial moves model LEA10AW
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 21, 2009 | Amana Dryers
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
I purchased an Amana drier a few years ago and my aunt purchased the exact drier the model #ALE331RAW It heats so hot you can not hardly touch the cloths
too hot??? thas gerenally a sign of insuffecient venting, check for arestricted and/or blocked vent. it cant release the proper amount of heat and its buildingup inhte machine
Mar 07, 2009 | Amana DLE330RAW Electric Dryer
Amana NDE2335AY Electric Dryer Logo
188 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
