Question about Philips Magnavox 51MP392H Rear Projection Television
Samsung HL-R6167W When set is first turned on there are green lines across screen, can't see picture. Unplugged it for 5 minutes and plugged it back in. Still has lines for a few minutes then finally comes on and has no problems after that.
    President:
  • Philips Master
  • 1,779 Answers
It sounds like either your Color Wheel or the digital control module is defective.. Have a svc co. verify.
Posted on Feb 26, 2009
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Problem with HL-R6167W green vertical lines
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
May 29, 2009 | Samsung HL-R6167W 61" HDTV
Do I have a bad dmd board?
Hi Dave I am Vortash if you replaced the Colour wheel and the problem went but then has returned I think it may just be a bad connection on the board check the ribbons from the lcds are secure and the plug slide that holds them in is all the way closed , also check the rest of the circuit for dry joints , I dont think this is as bad as you fear .. Regards Vortash
Samsung DLP TV bad picture
Some Samsungs have a problem if the set is turned on bfore the input put device due to a firmware issue. Try turning on the device (game, DVD, etc) BEFORE turning on the TV.
Let me know if this helped.
visit my site:
www.mcveyelctronics.com
May 02, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung HL-R6167W set turns itself off
sounds like the digital main board, seen this before
Jul 18, 2008 | Samsung HL-R6167W 61" HDTV
HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Mar 23, 2008 | Samsung DLP HL-P5663W 56" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
