Question about Polaroid FLM-2601 Television
I have power supply in hand
I have looked over the ps unit over and over and over again and do not seem to find anything wrong. This is mind boggling people. Anyone know what caps or resister or whatever is wrong with this thing that needs to be replaced? I can do the work just cant see anything causing a problem. I get the red light when I power on.
  • preludedez Mar 15, 2009
    The problem was a small solder joint that had popped on the green side of the board. Resoldered and it is working fine now
I experienced a similar problem with three FLM 2601 power supplies (from work). The two large caps that have hot melt keeping them in place are the typical culprits. They are located at one end of the module near the x-former.
Radio shack has the 35v 1000u caps for about $1.40 each.
Hope this helps.
Posted on Jul 16, 2009
Baseborad heater doesn't stop working
There should be a thermostat on each unit, if not there should be a thermostat on the wall for it. There is always the chance that an installer or builder/landlord was too cheap to put one in. You can buy baseboard thermostats and put it in yourself if you can turn off the power. They can be purchased at a big box or other builders supply. If it is on 230 volts get the double pole version of the switch. It may be mind boggling for some to figure out where to put all the wires so you may need help from someone electrically inclined.
Nov 29, 2013 | YouTube Videos
I hear two beeps when i conect power suply on my emachine t5212 model
Very sorry about your son.
If you can't find the real problem, you can always put that hard drive into another PC to get the files. If so, be sure to looking to a potential "jumper" setting on that drive for it to be recognized.
May 05, 2012 | E-Machines T5212 PC Desktop
Lacie ED mini v2 won't start up.
I had the same problem twice, but it was the power adapters each time that were causing the problem. It wasn't the unit itself. Lacie replaced the power adapters and it worked fine.
Nov 08, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Loss of power
I would start by checking for a fouled spark plug/wire. Also, check the fuel filter. It doesn't have to be good just because it is new. Could have a factory defect.
Oct 24, 2009 | 2003 Ford F250 Super Duty Crew Cab
Zooper replacement tires
You can try any bike store they should carry all sizes of tires.
May 28, 2009 | Zooper CoolZone Sport Stroller
Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
Dell Optiplex G110 power supply unit replacement
Yes you can replace the old defective power supply with the new atx but the problem is the size. It the size it fit to your computer nothing to worry because power supply now is almost the same output only the wattages changes.
Apr 11, 2008 | Dell NPS-110AB (NPS110AB) 110-Watt Power...
Beeping noise and no power
The "cricket" sound you heard can mean any number of things:
1. A component in the power supply that sets the frequency failed, causing a high frequency (hence over-voltage) in the SMPS, which then also failed. The initial failure may have occurred in a small high-voltage capacitor in the power supply (around 160V or so rated)
2. A failed horizontal drive or vertical stage, which drew so much current that the switching semiconductor in the SMPS failed.
Note that such failures often occur like dominoes (one, then two, then three, and so on). Sometimes the fuse itself will not even blow out. The best thing to do is to first remove the line-output transistor and then replace the switching semiconductor(s), nearby zeners, capacitors, and fuse if blown. Then turn the unit on and check for about 105V on the collector terminal of the line transistor. If that's fine then turn unit off, replace the line transistor.
Of course the above procedure is only a guide; the precise steps taken will depend on your exact make and model. Also, if the above sounds mind boggling then rather take it down to your nearest repair shop. Good luck.
Oct 02, 2007 | Sharp 20F640 20" TV
Enhance Power Supply only works unconnected to computer
Hi when under load the PSU voltage is obviously dropping off, With a Power unit, there are 3 things to keep in mind. They are too expensive and too dangerous to repair, Also inexpensive to replace. Regards mistyman
Sep 29, 2007 | Enhance Technology SFX-1211J, Enhance 110W...
Polaroid FLM-2601 Television Logo
312 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
