Question about Central Dual Temperature Heat Gun Kit 3h201k
I have to relight my furnace once every 2 weeks or sometimes once a week. It relights fine but just stops. I thought a draft hits and comes back down n blows it out but I just tried sanding it again and will try a small wire and poke into the line. See if the works. Any other suggestions ?
    Novelist:
  • 152 Answers
There are products on the market today that are called by many different names,depending on your geographical location. The device Im referring to is a "anti-back flow stack damper" that are available from many HVAC suppliers, in different flue pipe sizes.
Also, there may be an adjustment on your control  valve to slightly increase the pilots flame.
In more severe cases, the unit may not be getting  proper gas pressure to the control valve, or that  valve could be malfunctioning.
Good luck...
Posted on Feb 23, 2009
Why doesn't it light?
You find instructions on youtube.
Feb 03, 2016 | Procom ML300HGA Heater
Pilot light will not stay lit om furnace
No pilot feed or it is dirty and or cob webs may be disrupting flow. Clean every thing and relight.
Oct 21, 2013 | Omega Trane Furnace Draft Inducer Blower...
We have a residential Lochinvar Solution Boiler (model RBN090). Around 7 years old. For past 2 weeks pilot light keeps going out. 2 repairmen have come out. We have replaced the Gas regulator, the roll...
Take notice of the wind conditions when it goes out. If there is a draft, the wind can come in the room with the water heat from the flue and blow it out. Or it can come in the room from another way and exit from the flue and blow it out.
May 12, 2017 | Heating & Cooling
Atwood 6 gal w/h won't stay lit longer than 12 minutes
After it is stored for the 2 weeks, do you turn water on to it, then bleed out any air through the taps before lighting it? If not try that and see what happens and let me know if any different.
Mar 14, 2010 | RTO Atwood Water Heater - 6 Gal LP
Piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
Nov 12, 2009 | Frymaster Dean GF14 Deep Fryer
Bosch 2700es natural gas unit keeps going out requiring a relight
Actually, this comment if coming from the math building at LSU!!!! How nice.
Any ways......You probably have a faulty thermo couple. It is the easiest and cheapest thing to do so try that. Most units have reverse threads so keep that in mind when removing. It is identified by a copper wire that leads to the main control unit. It should also be held in-place by some clips that just pinch the copper in place. Replacing the new one will be just the reverse of the removal.
Hope this helps
Apr 14, 2009 | Bosch 2700ES Natural Gas AquaStar ...
Pilot blows out on n.g. tankless water heater when it's windy
There are many anti-back-draft systems on the market, but there may be only a few that could possibly be Incorporated in to your application. You might contact the manufacturer for their product list of, flue pipe anti-back-draft devices.
Good luck...
Feb 22, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Hi, I have an amanna sv80 natural gas furnace, I lost power to my home , my question is will the pilot need to be re-lit or will the furnace restart on its own? Thank you
The pilot light will be fine it is gas. The only way you need to relight pilot light is if you turn off the gas. The furnace should restart itself when the power comes back on.
Dec 16, 2008 | Heating & Cooling
Goodman Furnace m/n GKS90453BKAC
A constant red light (not blinking) indicates that the thermostat is not calling for heat. Of course you know it is but just to be safe, jump out R and W on the board. If it continues to do the same as you indicated, replace the board.
Dec 05, 2007 | Goodman GMS90703BXA Heater
Central Dual Temperature Heat Gun Kit 3h201k Logo
90 people viewed this question
Top Central Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Central Tool and Hardware - Other Expert? Answer questions, earn points and help others
