Question about ZT Group CISNET A7022 PC Desktop
My cisnet keeps saying the boot manager is missing. And I've tried to set the boot up. To the cd rom but it still won't let recovery cd reprogram the computer.
    Problem Solver:
  • 12 Answers
Go to bios and check if your cdrom is the first available boot device.
if not then make it! .
if it is and you can't boot from cd then your cd/dvd rom drive might be crashed. also check if your cd rom disk have dust scratches on it.
Posted on Feb 23, 2009
Need to do a factory reset on a presario cq58n and it wont let me
Step 1:
There are multiple instances when you would want to wipe your PC's memory clean and reset it to the factory defaults. Called "formatting," it is often the last-ditch effort to restore a PC to functionality. You will also have to format your PC if it gets crippled by viruses. Although these instructions are for the Compaq Presario, the steps are essentially the same for all Windows-based PCs. Be sure that you want to delete everything--this process is irreversible.
Back up any data that you want to keep by saving it to removable media, such as external hard drives, flash drives, DVD-R, etc. Unplug all peripheral devices, except for the keyboard and mouse. Turn on the computer. As the computer is starting, repeatedly press F1 to initiate the recovery process. When the BIOS setup screen appears, press the right arrow key to select "Boot". Press the down arrow key to select "Boot Device Priority" and press "Enter". Press the down arrow key to select "CD-ROM" and press "+" to move it to the top of the list. Open the CD-ROM tray, and insert the system recovery disk. Exit the BIOS setup by pressing "F10". Be sure to select "Save Changes and Exit". System recovery should initiate. If it does not, and the PC loads Windows, then you have either failed to set the CD-ROM at the top of the boot priority list or you exited the BIOS setup without saving. Press "R" to begin the recovery process. When prompted, select "Full System Recovery". Restart the computer when the process has completed.
Mar 09, 2013 | Compaq Computers & Internet
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
Sony desktop vaio computer keeps saying missing operating system
Your operating system is currupted. You will need to repair it or restore it, if your sony desktop came with a recovery/repair cd. If it did, insert the disc, turn on the computer, set boot priority either in your bios (boot options) or the startup screen to dvd/cd rom, and follow instruction. If it didn't come with a recovery/restore disc, you are in trouble, and will need a full windows installation via a windows operating disc.
Jan 30, 2011 | Computers & Internet
Cannot access cisnet system recovery. stays at PCAngel screen
go here and get this utility called (ultamate boot CD) from here ok: http://www.mrbass.org/ubcd/
this will help you with you problem has many utilities it is free from this site an dit is an iso file so burn image to a disc and then put in the rom turn off PC and then restart and will boot the disc and do some of the diagnostics on the disc and find the problem ok good luck and have a nice day the fixist
Aug 02, 2010 | ZT Group CISNET A7050 PC Desktop
Monitor went flashing. Won't boot. Says missing
You need to repair your windows system files.
for that insert windows disk or recovery disk into cd /dvd rom then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then you can see bios configuration page then go to boot menu and set first boot device as cd/dvd rom then save settings and exit from bios .
then it boot with disk follow the procedure on screen then first choose recovery console then type in console "chkdsk /r" it fix and recovers error on harddrive.
Then restart computer then again boot and this time choose R for "Repair previous windows" then it repair it then you can use your windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 02, 2010 | E-Machines W3107 (RBW3107) PC Desktop
Ntldr is compressed
An NTLDR is compressed error is pretty easy to fix(much better then NTLDR is missing errors!).
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Feb 25, 2010 | Microsoft Windows XP Home Edition
I have another computer that won't start. the screen says - missing \windows\systems32\config\system use original setup cd rom select r to start repair I tried but it doesn't work
you need bootable windows disk or recovery disk.
Then set first boot device as your cd or dvd rom.
when you power up the computer press F1 or F2 or "del" key to enter in bios then go to boot option then save settings.
thenh put cd in cd /dvd rom then it boot with disk.
Then it load some file wait for 5-7 minutes then it gives screen then press enter.
then followe the instuction.
Aug 08, 2009 | Computers & Internet
I have an old computer, a Packard Bell Windows 95. I'm trying to recover it. I have the Master CD and recovery disks but the computer keeps saying that the CD ROM is undetectable when it is connected. I...
have a look on the back of your new CD ROM drive where the long cable goes next to that is a small piece of plastic check that it is in the same position as the broken CD Rom this selects between slave and master switches hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Toshiba Satellite a135-s4427 Boot Manager Missing
its not the hard drive my frined, its the boot loader it has been deleted or it has been compressed the only way to fix this is to use the recovery cd you have, to boot from cd-rom you need to go into bios which is usualy F2 or F5 key, then under boot manager or somthing is the primary and secondary boot, change the primary to CD-ROM, then save it and restart then it should boot from cd-rom then you have do a start-up recovery.
Jan 22, 2009 | Toshiba Satellite P205-S6287 Notebook PC
When I try to boot up my Compaq Presario model no SR 1420UK, I get the message: “Windows could not start because the following file is missing or corrupt: <Windows...
You can download the hal.dll file from this site www.dll-files.com/dllindex/dll-files.shtml?hal most of the windows missing dll files you can find here.
Also download windows nt or xp boot image from the net and create floppies or cd rom from that to boot up.
IF YOUR HARD DISK IS AN FAT32 PARTITION ITS VERY EASY AND YOU CAN USE WIN98 BOOTDISK WHIHC IS SINGLE DISK AND CAN ACCESS THE WINDOWS SYSTEM FOLDER AND COPY THIS HALL.DLL FILE.
AFTER GETTING PROMPT GO TO
C:\WINDOWS\SYSTEM32
COPY THE HALL.DLL
problem solved
Jul 20, 2008 | Computers & Internet
ZT Group CISNET A7022 PC Desktop Logo
172 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
