Gps will not turn on or comes go and goes back out.
Waking up your c330...
If you left your Garmin c330 on running
the battery will have 1% life left. If you turn c330 back on again, it
will flash screen for 3 seconds then die, even charging it at this
point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the
power home or car into Garmin c330. There is a tab in the front Garmin
gray frame of your screen. You must take like your fingernails and
under the logo "GARMIN" pull the whole gray plastic frame off.
Underneath the plastic frame to the right hand side. There is a "RESET"
button. Make sure power is plugged in while hitting reset. Your battery
should come back to life. Cheers
Garmin street pilot c330 will not stay on. After turning the unit on the screen comes on for a second and is half the brightness that it should be, and then it brightness up and shuts down. Did this several times and the same things happens.
